Will these rims fit on my IROC?
Old Apr 30, 2003 | 12:48 AM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Question Will these rims fit on my IROC?
Since I have taken my IROC off the road I havent had time to build a shelter for it yet. SO it doesn a whole lot of sitting around in my backyard. And were coming into the rainy season here in Fl. My new Cragars keep trying to rust, if I dont clean the bastards every two hours. I want to take them off the car and put them indorrs covered up until I an get the car on cement with a roof over it.
In short I have a set of '89 Vette rims. They arent bad looking. I gues they are polished rims and need to be repolished. But anyway, I dont even attempt to take care of them, and they never change. I couldnt pay them to rust. They are 17x9 front and 17x9.5 rear. The fronts have tires and the rears dont. But they way vette wheels are designed I dont know if they will fit. I dont want to go find tires to fit them if they wont even bolt up. Will they bolt up or will the back of the rims hit parts of the frame/rearend or something before I get to the lugs?
Plus any techniques on restoring the vette rims would be nice.
Old Apr 30, 2003 | 07:24 AM
87DJP2001's Avatar
No. the vette wheels will not fit without using spacers. Wrong back spacing to use on your IROC with our screwed up off sets for the front and rears.
irocz8957's Avatar
yeah they should just bolt right on no problems!!!
Old Apr 30, 2003 | 08:26 AM
Jim85IROC's Avatar
Wrong. They use the same offset as the 4th gen f-body wheels. You need spacers to use them.
Old Apr 30, 2003 | 08:31 AM
caspergotaz28's Avatar
ehh...no they won't. Like said you will need spacers to make them fit.
The rims on an '89 vette have a very high positive offset (about +50-60mm) while the 3rd gen camaro rims have a 0mm (neutral) and +16mm offset for the front and rear.
If the car is just going to be sitting on a set of junk rims, you are probably better off using something like this or this. You can find a cheap set of burned off 15" tires at any used tire shop.
As for restoring the vette rims, I suggest you head on over to the "show and shine" section. (say that 5 times fast )
Old Apr 30, 2003 | 01:40 PM
DarthIROC's Avatar
Hmm and I guess spacers would be more expensive than just buiying another set of rims?
And I did put that in show and shine once and it didnt get a single reply.
Old Apr 30, 2003 | 01:46 PM
Spacers are gonna run you about $300-$350 for a set of four. Some sources for these are....
www.vettebrakes.com
www.skulte.com
www.performancewheel.com/adapters.html
and ya, show and shine is pretty dead. It seems this site leans more toward the "go fast" side rather than "look good" side.
Old May 1, 2003 | 07:25 AM
IROC5.7TPI's Avatar
You could always clean up your cragars then put a heavy coat of wax on them. They won't rust as quickly.
mschmidt33
Mar 15, 2015 07:20 PM
mark0006
Feb 28, 2015 07:12 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
dale3in98
Feb 14, 2015 12:18 PM
