Will Comp lifters for '87-up block work on a 400 SB? Need help fast!!!
Old Jun 9, 2002 | 08:17 PM
IgorT.455/406's Avatar
Post Will Comp lifters for '87-up block work on a 400 SB? Need help fast!!!
Hi guys. I have a set of 888-16 Endura X solid roller lifters I can get, CompCams, that I would like to use in a 406 buildup. I think they have taller bodies to clear a '87-up block. Will they work on a 400 SBC block. I would love to use them if I can, just need to know if they will work. I think they should 'cause the early block is shorter, these can work on both, BUT I am not sure. I need help fast! Thanks.
1981 Olds Delta 88 455/th400/3.23 posi
1988 Trans Am WS6, 355/T5/3.27 posi; RPM heads and Intake; Crane Fireball cam; Holley 750 carb; soon Comp RXE294H; th350 & 10" converter.
1994 Trans Am LT1/T56, no cat; Hooker CB; Hotch. SFC and STB; Ripper shifter; Poly mount; Lakewood LCA; K&N FIPK; Hypertech Airfoil; soon to port&polish MAF; Sprint springs & Bilstein shocks; GM Motive 4.10; Hypertech PowerTuner III
Old Dec 26, 2003 | 11:02 PM
91 GTA Ramair2's Avatar
Acording to P.A.W. it will .......
406 awsome Engine.
I'm BuilT one too, Mine's TBI injected.........
2bbl Holley 670 Cfm Tb's I got 2 of them
So you could say it'd dual Duce InJected 6.6L.
hey the Sound's Awsome to the ear's I'm going to have that painted on my Hood.
Anywho,That cam Should Slide right in and Kick some but.
406TBI=540H&620Tq@Flywheel,Still Love to Know After it goes threw the 700R4 and the AL drive shaft to the 3.73 geared 9" rear what i'll have at the 295/50R16 Drag radail's if I can find some in that Size..
Old Dec 26, 2003 | 11:10 PM
406sbc.
is a Good Engine You Should Yield some Nice power Decent Revabity.
You Got Anyother Spec's?? Like tranny Rear End??.
What kinda Car you running it In ??
Sorry just A 400 fan...
Old Dec 27, 2003 | 10:58 AM
Chris`s85Z28's Avatar
I thought only redro roller lifters would work in a non roller block? because I`m buliding a 383 and would love to go roller but I`m not paying 1200 when a flat tappet soild cam with lifters are $350
Old Dec 27, 2003 | 11:36 AM
Well, I am building a 383! I got a Scat 9000 series 1-pc crank and Scat 6" I beam bushed rods. Gonna run some SRP forged pistons and a 150-200 shot of juice. My heads are Victor Juniors, and gonna use my solid roller cam! Should work well in my third gen!
Old Dec 27, 2003 | 07:12 PM
Wait a minute you said your building a 406 your also building a 383?
My 383:
Scat 9000 crank
4340 scat 5.7 rods
KB hyper flat tops
I`m going for 400hp
Old Dec 27, 2003 | 07:19 PM
90rocz's Avatar
A 383 uses a 350 block and a 400 crank...A 377 uses a 400 block and a 350 crank...which are you building??
And Don't reuse the short rods of the 400SBC, at least use the 5.7rods of a 350.
Old Dec 28, 2003 | 12:19 PM
My 383:
Scat 9000 crank
4340 scat 5.7 rods
KB hyper flat tops
I`m going for 400hp
I was gonna build a 406, but still needed to find a good block. Then I got my Scat9000 crank and Scat 6" rods for x-mas, and I already have a good virgin 4 bolt 350 block. So gonna just build that with some good, forged pistons, and try to run Nitrous Works 75-200 adjustable shot!
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
alphaauto
Jan 23, 2015 07:42 AM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
