Will 79 rear end fit 92?
Old Feb 29, 2004 | 01:56 AM
SirChandlr's Avatar
I'm looking for a new rear end for my 92 firebird. I may have found a nice one out of a 79 firebird. Will it fit? If so will it fit well and with stock 92 wheels?
Old Feb 29, 2004 | 02:36 AM
aklim's Avatar
What brakes do you have in the rear? Disk or drum?
Old Feb 29, 2004 | 03:11 AM
transxtreme's Avatar
Will it fit? Yes it will, but not without serious modification. That firebird rear end is made for leaf springs not control arms. You can make it fit if you are good with a welder and you can fabricate well.
Old Feb 29, 2004 | 07:09 AM
87DJP2001's Avatar
Not exactly a bolt in. It will require way to much work and effort to make it fit. Why not find a 3rd Gen 9-bolt if you want a better rear. Just my opinion....
Old Feb 29, 2004 | 10:32 AM
Stephen 87 IROC's Avatar
Second gen diffs are also wider than first and third gen.
Old Feb 29, 2004 | 10:39 AM
SirChandlr's Avatar
ah, leaf springs, I should have thought of that. I'm not interested in any more fabrication. Thanks guys.
Old Feb 29, 2004 | 05:51 PM
Zepher's Avatar
Is there a torque arm provision on the 2nd gen rears?
Old Feb 29, 2004 | 07:34 PM
Not unless you have something custom made. There's one available for the 9" because it can easily be welded onto the steel housing. The GM diffs are cast and not as easily to weld to. You don't want a poor weld to break off the diff.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
