Why does my 305 NEED 91 octane??
Old Apr 24, 2005 | 12:21 PM
85_305's Avatar
I think I know the answer, but am not positive.
Ok my dad owned the car before me. He said that as long as he can remember it needed 91 octane. It is a 305 w/ 200k miles on it. Well, this past winter i tore it down and rebuilded it. I noticed that the Distributor was BEYOND shot, and that there was about 1" of slack on BOTH sides of the timing chain. (There was MANY more little things like this, but these seem to stikc out in my head for the question being asked).
Do you think that because of the distributor being shot, and having so much slack in the timing chain, was the reason why I was getting HORRIBLE economy, and why the car would ping if anything under 91 octane was used?
Thanx all,
Matt
Old Apr 24, 2005 | 12:39 PM
Black305RS's Avatar
Re: Why does my 305 NEED 91 octane??
the timing chain might have something to do with it but the distributer woul have a lot more to do with it. the pinging you heard was most likely pre-ignition because the distributer was set badly. higher octane gas is less volatile than lower so it takes longer to burn. the lower octane gas was mosti likely igniting during the compression stroke do to excessive heat build up in the chambers causing the ping.
Old Apr 24, 2005 | 01:53 PM
85_305's Avatar
Well when I took the dist. apart, underneath the cap where the rotor is was all white and stuff.. my hot-rodder friend Jim said that it was BEYOND junk, so I am taking his word for it..
But you dont think that because the timing chain was mangled, that the cam timing was advanced/retarded causing the engine to run differently?
Old Apr 24, 2005 | 01:59 PM
Black305RS's Avatar
it could cause that but timing chains usually dont slip even with a lot of play in them so id rule that out if that was the case your engine would probably trya nd hop out of the cradle lol.
Old Apr 24, 2005 | 08:48 PM
85_305's Avatar
^Oh ok.. I didn't know that there still wouldn't be any timing changes w/ play in the chain
BTW.. very nice Camaro Just keep playing with it and modding it.
Old Apr 24, 2005 | 10:33 PM
Black305RS's Avatar
thansk and i will but i didnt mean to say that there "wouldnt be" i meant that it most likely wouldnt be it can still happen but you generally cant jump time with a chain or so my teacher says.
Old Apr 25, 2005 | 06:58 PM
85_305's Avatar
Rob the car *was* stock, my dad got it w/ 32k miles on it in '90 or so. It had 200k miles when it was rebuilt. My dad said the ONLY gas taht WONT make it ping is 91 or higher. Do you think that because the dist. being shot it was requiring higher octane, or are you saying that is not possible?
Black305RS how old are you? BOCES, college or what?
Old Apr 25, 2005 | 06:59 PM
Black305RS's Avatar
lol im 21 i go to elgin community college for automotive ****,
Old Apr 25, 2005 | 07:55 PM
85_305's Avatar
^Oh thats neato; you like it?
Old Apr 25, 2005 | 08:51 PM
Black305RS's Avatar
yeah its fun i have access to machining tools which ill be using to port and polish my new 350's heads as well as a nify 3 angle valve job. i just wish their dyno worked but it costs too much to fix it. what sucks is i might have to bore the block i dont really want to siince that means ill have to get new pistons but if i have to ill do it.
Old Apr 25, 2005 | 08:56 PM
85_305's Avatar
^How much hp/tq you expect to gain from porting/3-angling your heads?
For a LONG time I wanted to be a mechanic, but soon after relized that computers was the way for me
Old Apr 25, 2005 | 09:19 PM
Black305RS's Avatar
somewhere around 20 at the most but thats streaching it but i dont really expect it to be near that maybe around 5 to 10 realisticaly.
its all about the little things though. it all adds up in the end.
hoswever i do know a little trick for certain piston types that will give about a 10 percent increase in torque
Old Apr 25, 2005 | 09:45 PM
85_305's Avatar
Only 5-10 hp?? Why is taht all? How would you expect from the heads on LG4's as they are supposed to port and flow REAL nicely ?
What might that little piston trick be ?
Old Apr 25, 2005 | 09:54 PM
Black305RS's Avatar
in general thats all i expect form ported heads it may be more but i really cant say. ive decided to give up on unreasonable expectation to avoid being disapointed in the long run.
it only applys to pistons with offset pins.
if you install them backwards you get more torque but the trade off is excessive wear good for drag cars though.
Old Apr 26, 2005 | 08:47 PM
85_305's Avatar
Why would putting them in backwards result in more torque?
Tarizza
Sep 20, 2015 03:26 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
dkred94z
Aug 20, 2015 03:09 PM
