Where is the Turn Signal Flasher Located?
Old Mar 19, 2003 | 01:33 PM
Proton's Avatar
Question Where is the Turn Signal Flasher Located?
I have an 88 IROC with the following problem:
- Left and Right turn signals light up, but do not blink
- Turn signal fuse is fine
- 3 front and 2 rear signal lights work light up fine ( checked not assumed )
- 1 front driver side signal burnt out. Its the one by the wheel well, but it has been burnt out for a few months and caused no problems.
- Hazard lights blink just fine.
Now I am led to the conclusion that it is the Flasher that is at fault. I believe there are 2 flashers, 1 for the hazards, and 1 for the signal lights. I found the one for the hazards between the bottom of the steering column and the radio, but I cant find the flasher for the signals!
I assume it looks similar ( small silver rounded can type thing ). Any help would be much appreciated.
Old Mar 19, 2003 | 03:05 PM
87DJP2001's Avatar
Should be in the same location. Turn on the turn signals and feel for the vibration. I hope you have small hands because that helps
in working under the dash. Keep looking on the right side of steering column.
Old Mar 19, 2003 | 04:15 PM
Proton's Avatar
Thanks for your help! I managed to find it clipped to a metal bar just above the 'convenience centre'. It was very well hidden and hard to get at.
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
