when changing ops
Old Sep 10, 2003 | 08:29 PM
lordmetalz28's Avatar
when changing ops
when changing my oil pressure switch. what should i keep in mind. should i use black silicone on the threads. how tight are they in there do they often snap. should i buy that special socket or just use channel locks
Old Sep 10, 2003 | 09:36 PM
angel71rs's Avatar
I prefer teflon (tape or liquid), but any sealer is ok. Threads are NPT; they taper so as you screw them in, they seal on the threads. So a huge amount of torque is not needed. Say 15 ft #'s. The socket is convenient, but I've used channel locks and adjustable wrenches in a pinch.
Old Sep 11, 2003 | 06:16 PM
angle how bout valve cover gaskets on a tpi motor . hard or easy just the top hex bolts do i need to scrpae the factory gaskets off the head with a razor should i use black silicone there to whats the deal i have to replace the ops and valve cover gaskets because im leaking a slight amoutn of oil enough to want to make me change it
jayblev95
Jun 7, 2015 04:04 PM
mdenz3
May 22, 2015 09:25 AM
May 1, 2015 01:14 PM
rwferguson43026
Feb 6, 2015 10:06 AM
NewsBot
Jan 21, 2015 06:10 PM
