wheel 3rd gen -to- 4th gen???
Old Feb 5, 2007 | 11:16 AM
slowpoke310's Avatar
hey do rims from a 4th gen fit on 3rd gen???
will z06 18x9.5 18x10.5 with 295
fit a 87 i-roc???
Old Feb 5, 2007 | 11:22 AM
Duke's Avatar
You need wheel adapters to make them fit. I have 4th gen wheels on my Camaro and had to use 2" spacers front and back. Got them from Skulte Performance. Do a search, I can't remember his URL.
Old Feb 5, 2007 | 05:54 PM
krisb410's Avatar
There a ton of them on ebay. I'm switching to a 4th gen rear and gonna use a set of 2in spacers on the front.
Old Feb 7, 2007 | 09:29 AM
Purple 92 SS's Avatar
I have a 4th gen rear, and use the Skulte Adapters on the front as well. I too use 18x9 Z06 up front and 18x10.5 in the rear (thats on my 92 RS)
Old Feb 13, 2007 | 11:07 AM
thanx guys, my buddy has a 87 iroc who's trying to put the z06's 18x9.5/18x10.5s, having some troubles
where can i find those adapters?
how much do they run about? hope their not an arm and a leg
Old Feb 13, 2007 | 11:11 AM
Angelis83LT's Avatar
http://www.skulte.com/product_info.p...products_id/55
There is the link for the 2" adapters. they run $150 a pair. but they are top quality.. and they are different then just a spacer. These actually bolt to your cars lugs.. then you bolt the wheels to the adapter. You will see what i mean when you look at them.. You are using all of the stud instead of just the end like on a spacer.
If You get just a spacer that goes in between you run a pretty good risk of breaking off lugs and doing serious damage.. Best thing to do is to just shell out the $300+shipping and do it right.
Old Nov 7, 2007 | 06:07 PM
stepuptata's Avatar
putting 4th gen on my stock 92 RS conv. Do I only need the 2" spacers on the front? Or front and rear. I thought just the front only, but just checking. Thanks.
Old Nov 7, 2007 | 06:14 PM
krisb410's Avatar
If your using the stock 3rd gen rear, then you will need a spacer/adapter.
Jason Short
Jan 19, 2015 06:33 PM
JoshGuitar
Jul 23, 2002 06:20 PM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
formula79
23
Jun 20, 2002 01:42 PM
