Whats wrong w/ temp gauge
Old Jan 25, 2003 | 05:03 PM
Black6SpdTA's Avatar
Hey I need help w/ my temp gauge. It stays at 100 all the time. When I start the car it goes over then back so I know the gauge itself is working. The dealer put a new sending unti in before I bought it so maybe thats the problem? Anyone have any ideas. thanks
Old Jan 25, 2003 | 05:34 PM
Dragons91RS's Avatar
mine was like that to. very rarely did it move from the 100 mark comes out the previous owner removed the thermostat. I put one in and my temp gauge works.
Id change the thermostat. even if it has one, it could be stuck open.
Old Jan 26, 2003 | 12:09 AM
krazzycowgirl's Avatar
Mines the same way but Mines that way for a reason. My car kept over heating even after we changed the Water pump, Thermo stat & even after it blow the rad. So my husband Hot wired the fans to the battery so the min i turn on the key my fans run 100% of the time. This summer before race season we are going to switch it to a switch or a thermal fan switch that will be hooked to the Rad. when it gets a temp then it will turn on then shut off when it cools down.
Old Jan 26, 2003 | 01:07 AM
90rocz's Avatar
Yeh, I'd guess it's either unconnected or wrong/bad sender. A common mistake is putting the one in for the "dummy-light".
Also a bad or disconnected oil pressure gage will peg over 60psi all the time, after started.
dylan1303
May 22, 2015 12:24 PM
Biggiebound
Apr 23, 2015 08:50 AM
Biggiebound
Apr 21, 2015 11:28 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
