Whats this part called
Old Oct 9, 2004 | 11:53 AM
Bruticus's Avatar
Hey all just a quick question what is this plastic thing here for the cooling that i circled in the picture called ?
Old Oct 9, 2004 | 01:35 PM
Ben91RS's Avatar
Re: Whats this part called
It's called a heater control valve, sometimes called a hot water valve. It keeps coolant out of the heater core until you turn the heat on. Not sure if your interested, but you can delete it.
Old Oct 9, 2004 | 01:57 PM
Damon's Avatar
Actually, it only bypasses coolant around the heater core when you select full cold on the hot-cold slider switch of the HVAC controls.
Yes, you can delete it and the bypass hose that goes with it if you do some work with the hoses. Set it up so that the coolant goes straight from the metal exit nipple at the back of the intake manifold directly into the heater core. Also, delete the "bypass" hose and plug the connection point where it feeds into the metal coolant return line on the pass. side frame rail.
Or just buy a new bypass assy. from your local auto parts store for a few bucks and put it in.
Old Oct 9, 2004 | 03:06 PM
Bruticus's Avatar
Really well any pictures or a step by step thing here.
Old Oct 9, 2004 | 07:19 PM
Ben91RS's Avatar
Oh, OK, I didn't realize that. I guess I shouldn't of posted if I didn't fully understand it. Oh well.
Anyway, it's pretty easy to delete it. First look at the hoses that go into it. There are 3 large 5/8" (one may be 3/4", I can't remember) heater hoses and 1 vacuum hose. Cap the vacuum hose with a vacuum cap and go ahead and remove the 3 heater hoses that are attached to the heater valve (have a cup or bucket ready for coolant to spill into. Next, remove the 5/8" heater hose that is attached from the heater valve to the large heater hose on the passenger side framerail, and cap that with a 5/8" heater hose nipple or block-off with a hose clamp (those can be found in the HELP section of any auto parts store). Now all you have to do is connect the two remaining heater hoses with a 5/8" heater hose plastic straight or 90* elbow and hose clamps (also found in HELP section). Now your done. Let me see if I can dig up some pictures for you.
Old Oct 9, 2004 | 07:31 PM
Ben91RS's Avatar
Here we go. It's not my car, but it's the best pictures I can find. This is a picture of the 2 heater hoses that you have to connect:
http://images.cardomain.com/member_i...83_25_full.jpg
http://images.cardomain.com/member_i...83_26_full.jpg
And here's a picture of the heater hose that you have to block off:
http://images.cardomain.com/member_i...83_27_full.jpg
Hope this helps.
Old Oct 9, 2004 | 11:00 PM
aklim's Avatar
Why are you bypassing it? Once you do, you won't have any heat so if you drive it on a cool day, it will be cool. Now, if your core was leaking, then you might want to do it if you don't want to tear out the dash to fix it.
Old Oct 10, 2004 | 12:34 AM
Bruticus's Avatar
Ahhhhhh so u do lose your heat by doing this by pass that blows. Are there any real gains outta this ?
Old Oct 10, 2004 | 07:10 AM
PyRo9862's Avatar
You don't have to loose your head bypassing the valve, you just make it so that coolent is always running through your heater core.
The only gain is it clenas up your engine bay.
Old Oct 10, 2004 | 08:51 AM
Ben91RS's Avatar
Exactly. You still have heat and AC.
Old Oct 10, 2004 | 11:40 AM
Bruticus's Avatar
Oh ok Thanks alot guys on the help and tips I am gonna try the bypass I will keep you informed.
Old Oct 10, 2004 | 06:14 PM
Bruticus's Avatar
Ok I did it !!!!!! lol Thanks on the help just was a major pain in the butt to plug that lower line tho but i did it thanks alot guys.
Old Oct 10, 2004 | 07:01 PM
PyRo9862's Avatar
I forgot to mention bypassing it will cause your water pump to only last about 6 months. Most people just buy one with a warrenty and keep going back for more.
If you didn't figure it out i'm just being a jerk. Enjoy your slightly less cramped engine bay and slightly warmer AC
Old Oct 10, 2004 | 09:06 PM
Bruticus's Avatar
Id figured u were being a jerk about that just figure I spend about 6 bucks instead of 30 just bypassing it.
Old Oct 11, 2004 | 12:29 AM
PyRo9862's Avatar
The part is $18 as I recall. Plus about $3 worth of antifreeze.
That damn thing breaks on every thirdgen (both of mine) and no parts stores have it in stock, so it takes a day or two. Next camaro I buy i'm doing that with the first tuneup.
