Whats a good rear end?
Old Sep 6, 2007 | 09:22 AM
  #16
Rice Killer87's Avatar
Originally Posted by Marc 85Z28
I'm running a 10 bolt in both the cars in my sig. The 85 Z28 runs mid 12s, while the 00 TA recently went high 10s, both NA. The Z28 has a budget/economy minded 355, and the TA has an aggressive H/C 346 setup. Both cars are full weight autos and run well for the mods because the combos were well researched
Well done! An auto will def. help that 10 bolt live,as well as no power adder....I love NA cars
EDIT: I love FAST NA cars
Old Sep 6, 2007 | 09:35 AM
  #17
85305Z's Avatar
I know appearance tastes are subjective, but don't do this! 85305Z - If you want to see how retarded this looks, I can point you to a local car...
And only some 16" stock wheels "fit"
what do u mean "how retarded it looks" what could it look like? i guess im confused, but id like to see it
Old Sep 6, 2007 | 11:10 AM
  #18
Marc 85Z28's Avatar
The wheels/tires move outward nearly 2" per side. Not only do they stick out minimally past the quarter panel, but having a tire stick out like they do with the narrow width just looks dumb. If you're familiar with the Glen Burnie/Pasadena area I'll point you towards one of these turds.
Old Sep 6, 2007 | 03:00 PM
  #19
krisb410's Avatar
I got a rear from a 95 z28, 3.23 posi from crazy rays for $80 (minus the rotors and calipers). I just cleaned it up, and pulled the axles. Everything looks great, so I painted it and installed new seals and bearings. I got the LS1 style brakes to install on it, along with a new 1LE prop valve and LS1 master cly (my car currently has drum rears). I have ZR1 rims on my car now, so I'll just drop the rear spacer/adapters that I currently have on the rear.
Old Sep 6, 2007 | 03:23 PM
  #20
85305Z's Avatar
aaaaah, got yea...so the rear end is slightly wider then a stock 3rd gens rear?
wow, good to know....i may have to check them out
Thanks!
Old Sep 6, 2007 | 03:30 PM
  #21
Marc 85Z28's Avatar
Just a couple of things:
1. The LS1 and LT1 axle assemblies are a different length. I went with an LS1 rear, and attempted to put LT1 brakes on it. It required a good bit of modification to fit - you'll have to do the same for LS1 brakes on the LT1 rear.
2. The 1LE proportioning valve is designed to work with a dual piston front caliper which you do not have. The LS1 master cylinder also is designed for dual piston front calipers. I would not use those parts!!
3. The stock master cylinder and combination valve for an original front disc / rear drum setup will work fine with keeping the stock front brakes and swapping to the LT1 or LS1 style rear disc brakes.
85305Z: As stated before the 93-97 rears are 4" wider than the 3rd gen rear, and the 98+ are almost 3.5" wider. The difference in widths between the 4th gens rears are where the brake interference issues come from.
Old Sep 6, 2007 | 04:16 PM
  #22
krisb410's Avatar
1. I already bolted up the LS1 brakes to the rear, no mods needed. Just bent my own hardlines.
2. I'll be putting on C5 front vette brakes.
Edit: My buddy did this 1LE prop and LS1 MC on his 91 RS with 1LE rear brakes and stock fronts brakes with no issues.
On a side note:
I won't have a parking brake until I modify some cables myself or someone offers them for sale, but since I have an automatic trans, I don't use it much anyways.
Old Sep 11, 2007 | 09:54 PM
  #23
n8sz28's Avatar
if your running after market rims instead of 4th gen rims you won't need the spacer for the front correct? the rear end will just be wider.
Old Sep 12, 2007 | 08:03 AM
  #24
85305Z's Avatar
got ya, thanks....but i guess if you find a wheel with the right offset then it shouldn't be a problem?
Old Sep 12, 2007 | 10:50 AM
  #25
Marc 85Z28's Avatar
A lot of people go with 4th generation F-body wheels when they put the 4th gen rear in. Like many others, I did the same, and put some 17x9 ZR1 style SS wheels on. The wheels are easy to come by and inexpensive. Some may say the ZR1 wheel is overdone, but they look really good, moreso on the 3rd gens... If you want to go this route, you will need spacers/adapters for the front wheels. You can find more info at www.skulte.com
Old Sep 13, 2007 | 10:38 PM
  #26
85305Z's Avatar
great, thanks alot
those were actually the wheels i was thinking about going with
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
