Whats the best way to put on an intake???
I am putting on my new intake and want to make sure everything seals properly. I have all fresh gaskets and Permatex Ultra Black silicon. I have a few questions.
1) What is the best way to go about putting on the intake and make sure everything seals properly so I have no oil leaks or vacume leaks?? Is there a method and a property way of applying the gaskets and silicon sealent? Also, do I have to let the silicone settle before dropping on the manifold?
2) What order do I torque the intake manifold bolts and to how many pounds.
Thanks in advance.
Nick
Thanks in advance.
Nick
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
see manual for sequence, 35 ft/lbs. use some sort of self locating guide in opposing corners, i used a shortened pencil.
i have always torqued it in increments from 15 ft/lbs - 25 ft/lbs - 35 ft/lbs
also not sure if this post is "advanced tech" hope that helps
sequence (from memory) don't quote me
8 - 7 - 2 - 3 - 9 - 10
front
6 - 5 - 1 -4 - 11- 12
front
Use quality name brand gaskets.
Toss the rubber end seals. Use the black RTV on the ends, 1/4" bead, and extend the bead from the block onto the heads about 1/2".
Apply small amount of RTV on gaskets around water passages to prevent leaks and to hold gaskets in place on heads while you drop the intake.
Apply thread sealer/RTV on intake bolts to prevent oil seepage.
Let everything sit for an hour so the RTV sets in place.
95chwagon
Jan 13, 2015 09:19 PM
