What should the stock oil gauge read at idle?
Old Nov 11, 2003 | 05:51 PM
samiam305's Avatar
I have a 92 305 TBI, and I am curious as to what the stock oil gauge should read when the car is idling. I know as I hit the gas, the pressure rises, but didn't know what it should read if I'm just sitting there
Old Nov 11, 2003 | 06:05 PM
Dave89IROC's Avatar
my 89 305 TBI reads about 15psi at hot idle
Old Nov 11, 2003 | 06:09 PM
samiam305's Avatar
So for education purposes, so the 15-30 range is ok at idle, and at WOT, it increases significantly?
Old Nov 11, 2003 | 06:13 PM
bmillington's Avatar
My old 91 305 TPI had about 10psi at idle and 35 above idle
My 92 350 TPI has 45psi at idle and 60 above idle, but I think might be something wrong with the sender (I hope).
Old Nov 11, 2003 | 06:15 PM
samiam305's Avatar
I don't know...my 92 is about 30-45 idle, and above 60 at WOT...that prompted me to ask the question.
Old Nov 11, 2003 | 06:35 PM
CamaroZ28Coupe's Avatar
my 83 z28 is like that too
the gauges are known to be wrong but as long as they are proportionally wrong then youll be alright haha
like for example just take the readings you get and understand that they prob are displaying higher then they are. but just use that higher number to determine if your lower then "normal"
glad to know I'm not alone
Old Nov 11, 2003 | 06:36 PM
Dave89IROC's Avatar
10 psi hot idle, and 10 psi increase for every 1000rpm increase is good
Old Nov 11, 2003 | 09:07 PM
aklim's Avatar
Mine reads 45 on a cold idle and if you go WOT, it will be around 60. If you warm it up, it reads 30 and warm WOT is around 45. This is with 5W30 in the summer and 0W30 in the winter. Mobil1
Old Nov 12, 2003 | 02:24 AM
oil pan 4's Avatar
My 5.0L 85 z28 has a rebuilt engine with about 10 thousand miles on it idels hot at 15-20 psi.
You oil can change your psi too I used 5-30 oil in texas during summer/fall.
Garcia5
Jul 7, 2022 06:51 PM
HectorM52
Jul 30, 2017 11:46 AM
brentbrowning01
Dec 16, 2014 06:35 AM
blac94Z
Nov 24, 2014 07:12 PM
