what headers does everyone use?
Old Feb 17, 2004 | 02:12 AM
  #16
Sitting Bull's Avatar
Originally posted by lt1g3n
well. no , its gunn be street/strip... but how much ofa hassle is it ? i dont want it to make me pull my hair out .. i just like the long tubes alot.. but ill go which ever way is better... i figured long tubes would let the lt1 breathe a bit more... or al ot more.. not sure..
A lot of folks curse their longtubes because of ground clearance problems. Every rumble strip results in them bottoming out, and so forth. The y-pipe has also been a problem for some folks to fabricate, as it tends to need to be bent at 90* angles because the collectors are further back under the car than shorties would be.
Personally, I'd go for shorties but it's up to you.
Old Feb 17, 2004 | 06:14 AM
  #17
408TA's Avatar
if your cam has a wide lobe seperation angle and mild duration then shorties are teh way to go. long tubes work better when you start running tighter lobe speration to aid in scavanging. if your cam is in the ball park of 224* duration at .050" and the LSA is 110* then go with shorties and a good Y pipe with mandrel bent exhaust, it will save in head aches and $$$$$$.
Old Feb 17, 2004 | 10:31 AM
  #18
slow_roc's Avatar
i have the cheap @$$ flowtech shorties under a 100 new shipped to my door, they work good, changing plugs isnt to bad (no a.i.r $hit also) get the y pipe like another 100 and for under 200 your good to go
Old Feb 17, 2004 | 12:08 PM
  #19
lt1g3n's Avatar
ok, well i looked at a few pics of long tubes, and they are so close to the floor, i know ill be bottoming out on the streets of chicago, so im going with shorties... now to decide which ones i want...
Now that im getting shorties, this means i can use the ones made for the motor/car of a 93-97 camaro lt1's right? Instead of getting the 82-92 ones, i can choose between both right?
id prefer to buy the ones for the 4th gen so that they have the D shaped ports.
thanks
Old Feb 17, 2004 | 12:14 PM
  #20
lt1g3n's Avatar
actually, whatever is going to work and perform best, im definately going with shorties now, i dont want any headaches... but i cant decide which ones i want.. id really like coated ones..anyone have any recommendations ? -- the guy at summit said to get the ones specified for the years of the car rather than the 4th gen ones..
so ya, coated shorties, price range tops at $400.00
thanks for all the help
Old Feb 17, 2004 | 12:45 PM
  #21
TheGreatJ's Avatar
You'll need to get 3rd gen headers, because the 4th gen front subframe is shaped differently and 4th gen headers might not fit.
Definitely get them coated.
Old Feb 17, 2004 | 05:53 PM
  #22
lt1g3n's Avatar
alright, i found my headers! thnx i went with in and out coated hooker shorties, thanks guys
Old Feb 17, 2004 | 09:24 PM
  #23
I think the shorties will make you happy
They'll give you that throaty rumble but still not bang into everything on the street.
Make sure to get a 3" intermediate pipe. That should be sufficient for up 400 hp or so.
Old Feb 18, 2004 | 09:20 AM
  #24
lt1g3n's Avatar
ah cool, yes i like hookers also!
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
