what headers does everyone use?
I am curious what headers all you 3rd gen guys are using on your 350's, and 305s, please list your motor size and application also , ie mods
Im looking to get headers but i dont know whats good or not, and i dont know if short or long tubes are better.. thanks guys!
i have Hedman on my car (shorty) 1 5/8" primary and 3" collectors. but they make a long tube version for 3rd gens now Hedman does,and i think Hooker does also. im not sure how well the long tubes fit,but my shorties fit EXCELLENT w/ no problems and are cheaper in price than alot of other headers.
long tubes are better for performance from what ive heard.
I have the Hooker 2055's for a 305. They're ok, they fit without any problems but the header bolt access and plug/wire access is horrid. My wires always seemed to find their way onto the primaries until I got wire looms; they're a must with any header.
Long tube headers are the best as far as performance is conserned, but they can be a pain fitting ect.
I'm getting hooker super comp 2210 for my 88TA. i'm putting a 400 sm blk in it. exhaust will be fun to make though. if you are running a 305 use 1 1/2" primary tubes. 350-383 can use 1 5/8" 400 1 3/4" this is just a rough guide line but its safe.
Hedman 1 5/8" shorties on an early-model carbed 350 with no emissions, making 300-350hp and backed by a 6-speed. The headers went in VERY easily and have no clearance problems. Plug access is great (I can change all 8 plugs in under 45 min) and since they're coated I don't have to worry about the headers rusting through. They're well-made and not half as expensive as some others.
FYI the only reason I went with shorties is the 6-speed....longtubes won't clear the clutch hydraulics without some modification which leads to a loss of ground clearance.
wow, this is great help guys, well i have a 350 lt1, im gunna go with long tubes since i have an auto trans, and im thinking of a flowtech coated ones.. i think they are called afterburnes, ever hear of em? I seen them on jegs for the camaro
http://www.thirdgen.org/techbb2/show...hreadid=148210
PS The hp and torque difference between shorties and longtubes is not massive and I personally wouldn't go through all the hassle just to gain a few more hp. But if this is a track ONLY competition car, then you really do have to go longtube.
well. no , its gunn be street/strip... but how much ofa hassle is it ? i dont want it to make me pull my hair out .. i just like the long tubes alot.. but ill go which ever way is better... i figured long tubes would let the lt1 breathe a bit more... or al ot more.. not sure..
by the looks of my engine compartment it doesnt look like im going to have any clearance problems... what would i have to change for long tubes, i really perfer long tubes .. i read that page, and he seemed to have to do alot.. but alot of others didnt have to do that much, or anything at all... i was lookin at hedman , and flowtech... and i think it was hooker..
From Summit
EDL-68721
Chevrolet/Pontiac: 1986-90 5.0L/5.7L TPI Camaro/Firebird, with 3 in. single slip-on catalytic converter, 16 gauge mild steel, Tubular Exhaust System $349.95
They are not on the car yet they will be by next month
EDL-68721
Originally posted by AutoRoc
Same here minus AIR tubes. Recently milled flat after seeing how terrible the sealing surfaces were in relation to each other..grrr
350 Crate engine, TPI intake, melling torquer cam, 1.6 roller rockers:
Edelbrock short/medium headers.
They wouldn't have been my first choice of headers, but they came on the car when I got it, so I guess they are better than nothing. It's DANG hard to get to the spark plugs. Though, they can be done with out unbolting the headers... just gotta get at them from top and bottom with a "custom" socket and one of those bent wrenches
