what do you think of this combo?
L98 350 Bored .30 over
Edelbrock Aluminum Vortech Heads
SDPC Vortech TPI aluminum Intake
SLP Intake runners Port matched to plenum and intake
Full Roller valve train with the following:
TPIS ZZ-9 Roller Cam Gross lift with 1.6 rocker is .515/.554 112deg lobe separation
Crane Gold Race Narrow Body 1.6 roller rockers
Manley hardened push rods ( w/guide plates ) OEM GM Roller lifters
24# GM injectors, flow tested and matched
Cloyes true roller double roller timming Chain
SLP 1 3/4 ceramic Coated headers Dual Cat type
ProComp Billet aluminum computer controlled distributor.
Taylor 8MM wires with Center bolt style separators
Crane adjustable Fuel pressure regulator
52 MM throttle body with integrated air foil and roller bearing throttle linkage.
52 MM port matched plenum
Custom ECU Prom with integrated diagnostics for recording car\ sensor data
Transmission:
Built 700R4, all new performance hard parts including "beast" sun shell, Servos, pump, boost valve, bands, bearings and clutch pack. Have reciepts
B&M Holeshot 2400 RPM Lock-up style torque converter
Should be pretty fast, no?
Transmission:
2 things will hold it back.....
B&M converters are no good.......get a good one
The TPI can't breath up top.....Look into the LT1 intake swap or look for something else....maybe a single plane injection kit or something.
With that done it will be a nice combo
Couple of things I would do differently. I would look into a different cam. The ZZ9 cam is of an older design and while OK there are now better cams on the market. I would look into the Comp Cams XFI268 cam. It is of a modern design with much better characteristics.
I would just go ahead and get the 58mm throttle body. It cost about the same as the 52mm. Just have to increase the throat diameters of the plenum.
Next thing is I would shoot for is a 10.5:1 compression ratio if not a little higher. You will want your dynamic compression ratio to be around 8.5:1.
You have a chance to make some really good horsepower so I would take a hard look at 30# injectors. Look into the Ford SVO style.
May 21, 2015 01:04 PM
Even has the same stall RPM
