What causes puffs of smoke on decel?
Old May 13, 2007 | 07:17 PM
scottd.'s Avatar
Long story short: Just dropped a rebuilt (30k on build) in the Maro..sent her off to get painted. On the way home I noticed some problems. Whenever I let off the gas, I get a small puff of smoke out the tail. The quicker I let off, the more the 'puff'. Under normal idle, no puff, no smoke. Ive also developed a nasty lifter knock. So, two questions.......
1) what causes the little puff on decel?
2) What would cause a lifter knock with solid lifters and is it related to number 1?
Old May 13, 2007 | 08:29 PM
85_305's Avatar
Hmm.. it almost sounds like the puffing is due to your valve seals being worn.. but if you claim there is only 30k on the rebuild, I really dunno..
Old May 13, 2007 | 08:37 PM
scottd.'s Avatar
I forgot to mention the engine sat for about 5 years before I installed it....which would account for dried up valve seals.
Now, for the knocking. What would cause knocking? Its pretty bad at idle, sounds like a hydraulic lifter that isnt bled up yet....(Im an old Mopar guy and used to hyd lifters...)
Old May 13, 2007 | 09:15 PM
85_305's Avatar
Ok so ya it's probably dried up valve seals. Common problem on Gen-1 SBC's. Especially after sitting for so long.
But the knocking.. you said in the first post, they are solid lifters. Now it sounds like you are saying hydrolic's?
Old May 13, 2007 | 09:16 PM
1987IROC350's Avatar
oil getting through the valves after being burned up by the spark plug. Just an educated guess. Usually Italian and German cars do this on purpose. It serves as a benifit when its designed that way. If not it is a definate wear issue.
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
blaze309
Sep 8, 2015 05:27 PM
86z28original
Aug 20, 2015 12:20 PM
alphaauto
Jul 26, 2015 04:40 PM
