Want a new hood
Want a new hood
I want a new hood for my RS but I don't know which kind to get. What do ya'll like. A 4-6" cowl induction, stock Z28 hood, SS style hood or any other kind. hopefully some of yall have some pics? thanks
hope this helps
http://www.carhoods.com/wherethewildridesbegin.htm
I personally like the "high-performance stock" look of the power blister Z hoods. That or a 2 1/4" cowl. Anything over 3" is just gaudy IMHO, unless you're a pro drag racer. If you can pull the front wheels, then a 4" cowl is cool.
Don't get a ram air hood....the whole mixing generations thing is just no good. It's like seein a 22 yr old blond with a 76 yr old geezer.
http://community.webshots.com/photo/...7726zSvbefUilh
http://www.thunderracing.com/images/...aunchfront.jpg
I dig the SS hood personally...
http://www.americansportscar.com/cgi....pl?ta-500.jpg
http://www.americansportscar.com/cgi....pl?ta-800.jpg
I have the 500 series one. Works well because my intakes hit the stock hood.
Personally Im very pleased with the SS hood.
HERE is a pic of mine.
Also check out the hoods section of the Thirdgen Appearance Guide
Ken
Ken
mixing generations
At http://www.carhoods.com/wherethewildridesbegin.htm in the pics none of the scoops are cut out. Are they just nonfunctional or are you supposed to cut em out yourself? Thanks.
From: Teeter-tottering between Brilliance and Insanity
Dude that SS hood looks awesome where can I order one of those from, I was gonna order like the liftoff 4" from summit for like $300 I thik but that SS looks way cool if its still in my $ range I may get that instead
hey MRBoss429x u can cut them or have someone cut them out for you, if they are nonfunctional they still can lower eng. temp
just make sure u put some mesh in there or somthing cause you just might end up with a bird under your hood
Tector~
Tector~
