vortech head question
i know i've gotta get the SA rocker arms. My cam has under .45 lift. can i use stock length pushrods and 1.6:1 ratio rocker arms? or should i just stick with 1.5:1?
------------------ Tyler Parsons '85 IROC-Z '94 Camaro 3.4L -160 degree stat, throttlebody bypass |
i'm guessing that is a .450"lift?? you could use 1.6rr's, they would only put you at .480 about. and you could use the stock springs too if that's all the cam your using. i still have my vortecs for sale! http://web.camaross.com/bb/biggrin.gif
Sure you can try using the 1.6 ratio rocker arms, but make sure you check valve spring clearance. The retainers will hit the valve guides anywhere from .450" to .480" lift.
------------------ 1991 Camaro Z28 350 L98 w/ T56 (originally 305 LB9 w/ T5) 318 RWHP, 419 RWTQ 12.803 @ 108.50 MPH (1.932 60') Member: SoCal F-Bodies ThirdGen 4-Life! |
well at my local auto zone, the guy i usually deal with revealed that he was building a 327 with all the vortech goodies. so he's going to hook me up with his brand new roller rockers for about 150, edelbrock rpm airgap intake for 200 bucks. all this stuff is still in its box. this engine is gonna be running very soon. http://web.camaross.com/bb/biggrin.gif
