Vortec Intakes
Old Jul 13, 2003 | 09:40 AM
Black6SpdTA's Avatar
Vortec Intakes
With Vortec heads, the only intake I could find are the 2 Edelbrocks, GMPP, and SDPC TPI intake. So I could run TBI (w/ adapter) or TPI. Is there anyway to "Ram" (SuperRam, StealthRam, MiniRam, etc.) a vortec headed motor?
-Rippin
Old Jul 13, 2003 | 10:49 AM
TheGreatJ's Avatar
I believe you can use the SuperRam with the Scoggin-Dickey TPI base. The Miniram and StealhRam won't work because the ports don't match up.
Old Jul 13, 2003 | 11:27 AM
Ski89Z28's Avatar
I think TPIS , miniram manufactures, now make a miniram to match up to Vortec heads or GMFAST Burn heads, don't know if they are the same.
Old Jul 13, 2003 | 11:58 AM
Chuck!'s Avatar
Yea the miniram 3 is vortec compatible.
Old Jul 13, 2003 | 01:35 PM
AutoRoc's Avatar
ghmcvh
GM Makes their own RamJet EFI manifold. You can get it in kit form which includes:
Intake
LS1 throttle body
fuel rails
fuel pressure regulator
injectors
knock sensor
distributor
and some other sensors, maybe MAP and MAT, not sure
It runs around $1100-$1300 If I remember right
That's my plan, I have Edelbrock E-Tec 200 heads which are Vortec pattern. Goodluck!
kolbaso
May 21, 2015 01:49 PM
dfarr67
Apr 10, 2015 07:44 PM
dawg irocz
Feb 10, 2015 10:33 AM
Lakebratt
Feb 5, 2015 07:55 PM
Chris Anderson
Jan 27, 2015 08:30 AM
