vortec heads??? help please
Old Jan 1, 2005 | 02:31 PM
streetheatz28's Avatar
Question vortec heads??? help please
i want to put GM vortec heads on a 1990 350 out of a silveraldo it says i need a vortec style intake and self adjusting rockers can i use these on this year 350 and if i can what would be the best brand to use ????
Old Jan 1, 2005 | 02:38 PM
96m6lt1's Avatar
Re: vortec heads??? help please
you definately need the vortec style intake,tbi or carb.you are still required to use the vortec style.as for the rockers you need SELF-ALIGHNING rockers.if they were my heads i would put larger valvesprings on and put screw-in studs as a minimum 2.00 1.56 valves would really be a benifit,you can get scorpion roller rockers for a mild set up or get the comp cams roller rockers for heavy duty rpm loads and strength.......
Old Jan 2, 2005 | 01:18 AM
zrs's Avatar
zrs
You can use non-adjusting rockers but will require guide plates and harden pushrod. Screw in stud is a plus if you plan on high lift/high reving engine. Use of larger valve spring would only be recommended if you go with a high lift cam as well as 1.6 rockers. This will require the heads valve guidesto be machined for higher lift. Do a search on thirdgen.org and you will get alot of info on vortec heads.
Old Jan 2, 2005 | 01:24 AM
Chuck!'s Avatar
Yea, if you want a decent lift cam then get your valve guides machined, other than that I run an Edelbrock Performer RPM manifold with a carb -> tbi plate. Edelbrock also makes a throttle bracket that you'll want to use with vortec heads.
Old Jan 2, 2005 | 06:06 PM
zrs's Avatar
zrs
Why not use the Edelbrock air gap rpm manifold. It's about $225.00 from summit.
Old Jan 3, 2005 | 01:24 AM
kandied91z's Avatar
i have a set of fastburn heads and vortec/fastburn tpi intake for sale just in case your buying new.
http://web.camaross.com/forums/showthread.php?t=329721
dfarr67
Apr 10, 2015 07:44 PM
dawg irocz
Feb 10, 2015 10:33 AM
Lakebratt
Feb 5, 2015 07:55 PM
Chris Anderson
Jan 27, 2015 08:30 AM
InfernalVortex
Jan 17, 2015 09:35 AM
