iroc question
Old Dec 30, 2004 | 08:12 PM
Irocdriver89's Avatar
iroc question
i got a quick question i had a weird thing happen today but i don't think there connected i opened the radiator and there was some foam like coming to the top .the reason i opened the radiator is because the car started to run bad it never shut off but it was running bad shakeing and when i got to like 60 the hole car would shake what could it be.
1988 iroc camaro auto 305 tune port injection k and n and flowmasters
Old Dec 30, 2004 | 09:45 PM
V8Rumble's Avatar
Re: iroc question
Errr... That doesn't sound real good...
Let me ask you this - do you have any smoke (particularly whitish-colored smoke) from the tailpipe? If you check your oil, does the oil on the dipstick look OK? When you popped the radiator cap, what did the coolant & the inside of the radiator look like?
Any other symptoms you've noticed?
Old Jan 3, 2005 | 01:14 PM
Re: iroc question
sorry about the response time but i have been praying that it is not a head gasket there is little smoke only on start up and the oil is black not milky but a local mechanic said that it is the first stage of a head gasket so will see soon i guess
Old Jan 3, 2005 | 01:37 PM
96m6lt1's Avatar
Re: iroc question
the heads are most likely cracked,its only a matter of time if you want to save the shortblock just get another set of heads done and replace or just get a fresh 350 built while still driving the car...
mark0006
Feb 28, 2015 07:12 PM
dale3in98
Feb 14, 2015 12:18 PM
dawg irocz
Feb 10, 2015 10:33 AM
capebuf
Jan 13, 2015 07:22 PM
