very confused, Alt wiring..HELP!!!
Old Jun 25, 2005 | 11:06 AM
doug791's Avatar
The wire that runs off the alternator that charges the battery, goes near where the battery is on the passenger side of the car, and into this black cylinder. Now that little black cylinder has two other wires that also plug into it, then come out into a weather pack connector, whos wiring then dissapears into the wiring harness.
What are these two little wires that go into that piece? I have a brand new wire to run from the alt to the starter but it would bypass those two little wires.
Old Jun 25, 2005 | 07:12 PM
NastyTA's Avatar
Re: very confused, Alt wiring..HELP!!!
Why are you running a wire from the alternator to the starter? There should be a two-wire plug on the engine harness that goes to the voltage regulator in the alternator. The wire on the back of the alternator that's on the stud and should be at least 10 gauge wire, runs to the +12v terminal on the battery. Not sure what the box is that you're talking about. The only wires that should be going to the starter would be the +12v cable right from the battery, the purple signal wire from the starter relay, and the power feed to the fuse block from the starter.
Old Jun 26, 2005 | 02:33 AM
doug791's Avatar
When you have the battery in the trunk its just as feasable to run the wire thats supposed to go to the battery to just run it to where the battery wire is at the starter. The other wires i were talking about are spliced into the wire that charges the battery, one is for a fan fuse, and one i think dissapears up into the wiring harness and is for the computer (its orange). I found a solution to the problem that im too tired to remember how to explain. Now if only i could figure out how to use a soldering gun lmao i cant get the solder to melt at the tip of the gun?! Ive soldered literally thousands of connectors with an iron so ill probably just go out and buy one of those tommorow.
Nayr
Mar 3, 2023 08:34 PM
Boss002
Jan 20, 2016 12:17 PM
raroz28
Sep 8, 2015 06:10 AM
WPHIG2
Aug 27, 2015 06:37 AM
Gtpguy
Jan 26, 2015 04:50 PM
