vaccuum leak and startup
Old Feb 22, 2005 | 11:35 AM
85irocrebuildtpi's Avatar
i have a question?
can a vaccuum leak on my intake affect my cold startup. i.e. too much air leaking in from runners lets say causes a flooding of plugs and no startup?
if so, how do i test for a vaccuum leak with my air intake system plenum and runners?
Old Feb 22, 2005 | 11:54 AM
87DJP2001's Avatar
Re: vaccuum leak and startup
A vaccum leak at the intake gasket will definitely affect your start up and idle.
Old Feb 23, 2005 | 05:03 PM
Rice Killer87's Avatar
a way u can find a vacuum leak is by spraying some WD-40 or brake clean around the suspected areas and if the idle jumps up,theres a leak. now,i have never done this myself,but have heard of it being done.
have u checked and double checked all the vacuum hoses and lines for leaks? they can be hell to track down..
good luck man
Old Feb 23, 2005 | 09:23 PM
Marc 85Z28's Avatar
NO, NEVER DO THAT! WD-40 can cause excessive carbon buildup and valvetrain issues, and brake clean (especially the chlorinated blend) will nearly kill you from the fumes. It'll suck the air right out of your lungs.
Use carb cleaner
magman
Apr 15, 2016 03:08 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
