unopened/sealed can of brake fluid what is the self life, dot 4
Old Mar 2, 2003 | 12:25 AM
BLACK Z !'s Avatar
I have 2 cans of dot 4 that I brought for my car about 2 maybe 3 years ago,which I misplaced so I brought 2 more, I want to change my brake fluid in my car and was wondering if I could use it or if I should throw it out. Thanks
Old Mar 2, 2003 | 06:48 AM
jzajac1's Avatar
Shelf life is indefinite if the seal has not been broken. Once you break the seal it's the moisture in the air that attacks the chemicals and shortens shelf life. What you have is safe to use.
Old Mar 2, 2003 | 08:06 PM
Sitting Bull's Avatar
They say the struff to get is the silicone-based brake fluid, as it will not absorb water like the glycol-based older stuff does. Saw that on Dream Car Garage today
Old Mar 3, 2003 | 06:47 AM
jzajac1's Avatar
If you plan on using silicone fluid, you must flush your entire brake system first. With the exception of silicone brake fluid, all other brake fluids are polyglycol based. If you mix the two fluids you change the viscosity and it will change the way some high performance ABS systems operate (not to the degree of poor braking but it does make some changes depending on the ABS system). Silicone and polyglycol do not mix well. Silicone is a excellent brake fluid but even then you can trap moisture in your brake system. Since water (moisture) is lighter then silicone it will travel to the bottom of the fluid reservoir, from there the moisture will work it's way down to the calipers and form tiny air pockets with moisture trapped in them. If your vehicle sits for extended periods of time, corrosion then forms, etc,etc,etc....
If you go on the web there is much to read about pros and cons of silicone based brake fluids.......They are good and it's a personal choice on what you use but do not mix the two.....
CGM2010CAMARO
Apr 7, 2015 07:44 PM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
captcorvette
Mar 7, 2015 12:37 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
