underdrive pulley for hp
Old Jul 6, 2003 | 10:27 PM
lordmetalz28's Avatar
i have an 87 iroc-z im thinking about getting underdrive pulleys but im having voltage problems as it is so i was thinking about just getting the crank and water pump pulley if i run these 2 pulley how much hp should i gain also will it affect my water pump in anyway as for cooling
Old Jul 6, 2003 | 10:37 PM
Rice Killer87's Avatar
i would guess about 5-10 HP gain and most likely,yes u will have some cooling problems. i would think u would notice them when ur sitting at a red light rather than driving down the road.
Old Jul 8, 2003 | 07:36 PM
IROC-T's Avatar
Power & Amp Pullies
March sells a set of pullies that turns your altenator at a higher speed,this should help with your charging problem. The set is called Power & Amp by March.
T.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Rde Bandit
Mar 21, 2015 10:17 PM
