How to bore a cylinder
Old Jul 8, 2003 | 01:51 PM
Black6SpdTA's Avatar
I was wondering. What is the exact process of boring a block?
-Rippin
Old Jul 8, 2003 | 02:50 PM
DrDUKE's Avatar
make them watch that American Idol show.
Old Jul 8, 2003 | 03:02 PM
Jim85IROC's Avatar
Just wrap some sand paper around a drill bit, and use a high speed drill. make sure to check it often with a ruler to make sure you don't overbore it.
Old Jul 8, 2003 | 03:26 PM
slayer6x6's Avatar
Are you serious?
Old Jul 8, 2003 | 03:51 PM
NTChrist's Avatar
Yes, but I use my tape measure rather than a ruler.
Old Jul 8, 2003 | 04:25 PM
What?!?!? Wait, so how do you get it in a PERFECT cirlce? I understand honing is making sure the cylinder is perfectly round but...wow. No offense but is that a ghetto bore job or like how a machine shop would do it?
Old Jul 8, 2003 | 05:20 PM
12Second3rdgen's Avatar
Wink
lmao they are joking
Old Jul 8, 2003 | 06:43 PM
Chris`s85Z28's Avatar
you guys are funny I almost pissed myself
I`ll tell the poor guy how they do it
you have to bring it to a machine shop and they have this machine that is a big round thing that have blades sticking out from the sides and there ajusted for how much of a over bore you want thats the best i can explain it
Old Jul 8, 2003 | 09:24 PM
slayer6x6's Avatar
To bore a block you need a a boring machine, you cannot use sand paper and a drill. You can hone with a drill and a honing bit, but if you take it to a machine shop (and they do it right) when they hone and bore the block they will even torque the main caps down to proper spec because it can distort the cylindar walls that much. Block boring is usually not done as a performance mod, it is done if the cylindar walls are too damaged that honing cant fix (taper, out of round, grooves, etc). When you bore a block it is a rough cut and must be honed after to clean up the cylindar walls and get the right crosshatch angles.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
jayblev95
Sep 26, 2015 09:44 PM
Z Power
Sep 19, 2015 11:19 PM
heus
Sep 8, 2015 12:01 PM
