two questions....
Old Jan 8, 2003 | 11:23 AM
Iratate4k's Avatar
Red face two questions....
k...can someone give me an estimate on how much an LT1 engine would cost? Saving up and I should be able to purchase something by the summer. Also I did a 1/4 mile the other night and got myself a 15.3 @ 89 and my camaro currently is a 305 tpi 89. My friend said I could get a better time if I know how to start off right and I'm asking you guys, the genius guys...how does one start off quickly? whats the trick?
Old Jan 8, 2003 | 05:48 PM
stevem's Avatar
i would lower tire pressure to about 26psi
in the rear
Old Jan 8, 2003 | 05:55 PM
Iratate4k's Avatar
why?
the standard psi in the rear tires especially is 33-34....i forget. explain why is it that I wanna lower my tires psi to 26 that's awfully low and I'm not seeing how it would get me off the line any quicker than if I had the standard psi needed in the tires.
Old Jan 8, 2003 | 09:46 PM
I EAT T/A's Avatar
First off, do you have an auto or manual???
Second, lowering your tire pressure makes your tires soft, flexible and gripier (if thats a word).
Hope that helps.
Old Jan 8, 2003 | 10:22 PM
jd13's Avatar
Lowering the pressure in your tires does help with traction to a point, but also increases wear.
Is your '89 stock? If so that's not a bad time at all.
Auto or manual?
SKmaroZ28
May 17, 2014 07:17 PM
PaNaRaMuH
Jan 27, 2013 10:53 PM
Collector Car
Nov 5, 2012 02:59 PM
