tuned 305 TBI
Old Aug 14, 2005 | 09:20 AM
Unix's Avatar
tuned 305 TBI
Hi,
I am just about to put together a slightly tuned 305 1989 TBI Camaro engine with a T5 gearbox, and I'm wondering about the HP it might produce
here are the parts that are going to be installed, bear in mind the stock engine has 170HP.
* LT1 camshaft, new timing components -pushrods, chain etc.(not stock)
* Be cool High performance thermostats 160' degree
* Hypertech cool fan switches 176' ON, 166' OFF
* Accel ignition control module
* MSD Distributor Cap and Rotor Kits
* MSD Heli-Core Spark Plug Wire Sets
* FlowTech Headers, shorty style
* MSD ignition coil
* open air filter
i know it's not much, but what HP and TQ gain can i expect from this setup?
any comments (positive or negative) are welcome, any suggestions etc
regards
Unix
Old Aug 14, 2005 | 05:19 PM
hallbilly's Avatar
Re: tuned 305 TBI
no headers or exhaust? IF yours actually put 170 down to the wheels then I would guess 190hp and maby a little more tq... but i remember seeing some post a few years ago on 3rdgen.org where people's dyno numbers on stock tbi cars were 150-160hp and around 255tq... get it dynoed and tell us! Good luck
Old Aug 14, 2005 | 10:40 PM
rollingstock's Avatar
Re: tuned 305 TBI
"* FlowTech Headers, shorty style "
Old Aug 16, 2005 | 12:42 PM
Unix's Avatar
Re: tuned 305 TBI
Originally Posted by Gunny Highway
1.) you're going to need a PROM tune with that cam
2.) no cat-back???
3.) maybe around 210 FWHP
1.if i don't do the prom tune will the engine run ok anyway? i'm not into performance too much so i just wan't the car to accelerate and idle in a decent manner.
2. the catalytic converter is cut out, there is only 1 muffler with 2 outlets in the back which is gutted , should be ok
3. jeez that'll be a nice upgrade since i'm going from my V6 135hp
i'm concerned about this prom tune, since in Poland there is really 1 garage where they know what they're doing with f-body computers, and it's not cheap as u might guess.
Old Aug 17, 2005 | 11:25 PM
85_305's Avatar
Re: tuned 305 TBI
2.) no cat-back???
I would listen to this man. He took a POS TBI and made it run like a champ
BUT.. with the stock intake/heads on that TBI, your really going to be choked up. If you could somehow slap some other heads/intake on there, your power will be significanly be increased over waht you will be pushing w/ everything done w/out the heads/intake.
But there is two guys on the board that tune PCM's. Do a search for PCM-For Less and shoot.. what's the other one? Anybody?? The guys name is Ion. Search that name But these guys should be able to hook you up w/ a good tune.
88IROC_Z
Jul 22, 2015 11:38 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
Jmlcolorado
Jul 4, 2015 08:31 AM
