Trunk Dont Open
Old Jul 4, 2003 | 12:18 AM
Kuruption562's Avatar
Trunk Dont Open
Any help? it was workin fine one day, then the next day it just didnt open. I dont got the key for the Trunk Either
Old Jul 4, 2003 | 12:34 AM
kevin 2.8's Avatar
Angry
i have a pretty bad/sad story to add to this post, maybe we can resolve both
im glad the car has back seats, or i would have no place to put my stuff.
my trunk worked, it worked great, i could put stuff in it and i was happy. the power trunk pop motor didnt work. the car came with a new one. i said "this doesnt look to hard" so i took the old one off. easy.
i put the new one on. easy. it bolted in, and the hammer from the pop motor slipped under this gear that goes to the lock fine.
i closed the trunk and went to the button to see if it worked.
i pushed the button *thunk* "yay it worked" i said cheefully, proud that i got it right the first time without even being too sober.
but the trunk was not popped. i tried the key, it would not turn. i immediatly realised i put the hammer on the wrong side of the gear. i already have enough keys to this car i dont want to wreck the lock by drilling it all out. then id have an ignition key, front door key (i replaced the locks) a gas cap key and if i drill it a seperate trunk key?! i dont want that.
the rear panel to the trunk is loose, i didnt reattach it to the body, but my car has that 'trunk hinged cover console stowage' thing. so i was thinking, maybe i could dremel into that bar thats on the hatch with a carbide bit, if i can rip that back plastic panel off.
or does anyone else have any ideas?
Old Jul 4, 2003 | 11:04 AM
lordmetalz28's Avatar
my question is if my trunk motor does break is there any possible way i could manually lock it myself i hate the whole motor idea.
Old Jul 4, 2003 | 02:09 PM
kevin 2.8's Avatar
just if you have the key you can flip down the licence plate
Old Jul 4, 2003 | 02:45 PM
Is the key a seperate key from the Ignition/Door/Fuel?
Old Jul 4, 2003 | 02:47 PM
doug791's Avatar
from stock its the door key
Old Jul 4, 2003 | 04:47 PM
Unhappy
So what am i to do in this situation?
Old Jul 5, 2003 | 01:13 AM
doug791's Avatar
how do you not have a key for the door? Unless you happen to have a remote opener??? just thought process...have to have key to lock car....try same key on trunk....
Old Jul 5, 2003 | 02:44 AM
Unhappy
I gots an Alarm to open my car.
Old Jul 5, 2003 | 10:06 AM
kevin 2.8's Avatar
buy a set of lock cylinders
Old Jul 5, 2003 | 01:09 PM
but how do i get it to open?
Old Jul 5, 2003 | 01:26 PM
kevin 2.8's Avatar
you may have to cut somthing off like im probably going to have to
either the lock or the bar that latches the hatch down
Old Jul 5, 2003 | 01:32 PM
Aaront810
Aug 29, 2020 09:34 PM
NewsBot
Sep 30, 2015 04:20 PM
Tarizza
Sep 20, 2015 03:26 PM
tommalcolm
Sep 11, 2015 03:39 PM
Toxintwins
Sep 11, 2015 11:13 AM
