Transmission Temp.
Old Dec 18, 2002 | 03:33 PM
Irocvette355's Avatar
Lightbulb Transmission Temp.
I was think about putting a trans. temp. gauge in my car, just to monitor when I do auto-x. You guys think i can install one where the drain plug is on my t-5?
Anyone ever done this?
Old Dec 18, 2002 | 11:32 PM
Stephen 87 IROC's Avatar
I doubt you need one. A manual transmission doesn't create a lot of heat unless you're pulling heavy loads. There's no way an F-body could heat up the oil in a manual transmission high enough to need to worry about it.
An automatic transmission should have a gauge with a high stall torque converter because the converter makes a lot of heat. High temperature is the number one killer of automatic transmissions.
Lack of oil kills manual transmissions.
Old Dec 19, 2002 | 12:08 PM
TheGreatJ's Avatar
Sure you could put a sender there with the appropriate fittings, but I agree that it would be relatively pointless. Engine oil temperature could be good to know, but trans temp is only important for automatics.
Sep 27, 2015 01:55 PM
plattted
9
Sep 20, 2015 11:23 AM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
