Transmission cooler
Old Nov 27, 2004 | 11:32 AM
zrs's Avatar
zrs
Transmission cooler
Will be using a high stall converter and need a tranny cooler. Looking for recommendations and maybe some pictures of where you mounted the cooler.
Old Nov 27, 2004 | 01:28 PM
85_305's Avatar
Re: Transmission cooler
Here ya go..
http://www.jegs.com/cgi-bin/ncommerc...89&prmenbr=361
btw.. dont break the bank man, these f'er's are expensive
Old Nov 27, 2004 | 02:32 PM
transxtreme's Avatar
Mounted mine in front of the radiator in the lower right side with its own fan.
Old Nov 27, 2004 | 08:44 PM
zrs's Avatar
zrs
which would you recommed for a 2800 + stall converter.
Old Nov 27, 2004 | 10:54 PM
85_305's Avatar
Hell.. Me personally, I go all out when it comes to engine and driveline cooling. You are talking about a high-performance tranny, that is handling a lot of power and will prolly be abused a bit. Why not spend an extra $20 or so, and get the best cooling you can. Tranny's run hot, keep it kool Just get that 28,000 gvw or whatever it is.. that is what I would do anyhow.
Old Nov 28, 2004 | 08:10 AM
aklim's Avatar
If you drive it in the winter, I would not get the biggest and baddest because the fluid might get too cold. Otherwise, if this is a summer car, get the biggest.
Old Nov 28, 2004 | 10:29 AM
zrs's Avatar
zrs
Thanks for the all the info. I went and ordered the 20,000 GVW part 400-3820. As far as winter goes, that never even crossed my mind but then again I live is Southern Cali. (for now that is)
Old Nov 28, 2004 | 11:55 AM
85_305's Avatar
It doesn't really matter if the fluid gets cold aklim, not going to hurt anything.
BTW.. good choice. Flex A Lite products are GREAT products
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
rideordie
Sep 7, 2015 08:22 AM
