tranny trouble
Old Mar 9, 2003 | 09:39 AM
YellowZ28's Avatar
tranny trouble
I have a 87 z28 automatic w/ a 700 R4 tranny. I recently did something to it in the snow. IT shifts reverse and first gear manually on the shifter but when driving it doesnt shift out of 1st gear. Could it be a cable or does it sound like it is blown?? Also, is getting a rebuilt one if it is blown a good idea or should i just go with a new one. Any info will be apreciated thanx.........
Old Mar 9, 2003 | 12:12 PM
TheGreatJ's Avatar
I assume by the "I did something in the snow" that this is a sudden thing. If it was gradual I'd just say change the fluid and filter, but if it's sudden you either broke something internal or managed to overtighten the HELL out of your TV cable. Try adjusting the cable just cuz you can do it yourself in a few minutes, but I don't think that's the problem.
As far as replacing the tranny if you need to......there's nothing wrong with a rebuilt tranny as long as the rebuilder knows what he's doing. A good tranny guy will give you a warranty on his work, and the rebuilt tranny will be much cheaper.
Old Mar 10, 2003 | 09:55 PM
kjlvilla's Avatar
If it will not shift out of first ever, even hard throttle, check the governor. When you pull it out there should be a little plastic gear on the bottom. the entire gov. should turn with it. This makes your trans. upshift, the t.v. controls when.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
