tpi swap help
tpi swap help
i have a friend that swapped an 88 tpi from a vette into 84 z28the motor will run when primed!!! injectors wont fire what will keep them from opening ??? what wire makes them hot as far as i can tell there is no fire to the inj!! computer and wiring harness came as a hole unit from the fire wall out just bolted the harness into the camaro spot is there another hot wire that needs to be connected separtly or what any help is always greatly appreciated!!!
Check the grounds on the harness there should be 2 or 3 on the back of each head and one fron the right head to the firewall to complete the circuit. I believe the injectors have a constant hot and trigger by getting grounded.
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
