tpi mystery canted valve heads?
Old 02-08-2012, 12:47 AM
clemente's Avatar
ive got a pair of heads on a tpi that i acquired a couple of years back and would like to rebuild the tpi before i put it in my hopefully new to me iroc z but i have no idea where the heads came from and was hoping to get some info in here that would help. the only casting numbers i found on the right side head was "sn 13357-2" and inside the valve cover i found a series of numbers that i hope can help. a circle with an A inside of it, a 1 under that, and 2635 undern that.
clemente is offline
Old 02-08-2012, 12:58 AM
clemente's Avatar
Re: tpi mystery canted valve heads?
for some reason i cant add pics. but the heads are aluminum with canted valves like the 454 and canted spark plugs like the lt-1. they have no markings front or back to let me know where they came from and they have a center bolt pattern for the center bolt valve covers. and i dont know if it matters but, it has a set of roller rockers with hydrolic lifters and a roller cam a presume.
clemente is offline
Old 02-08-2012, 08:02 AM
knta4dnu's Avatar
I would go to Thirdgen.org for help with this one.
knta4dnu is offline
Old 02-08-2012, 08:25 AM
96capricemgr's Avatar
I know Trickflow made a FEW "twisted wedge" LT1 heads, seems reasonable if they bothered for the LT1 they would have made some Gen 1 ones first.
I have no specific knowledge but maybe this gets you somewhere to start looking.
96capricemgr is offline
Old 02-08-2012, 08:47 AM
Marc 85Z28's Avatar
Originally Posted by 96capricemgr
I know Trickflow made a FEW "twisted wedge" LT1 heads, seems reasonable if they bothered for the LT1 they would have made some Gen 1 ones first..
TrickFlow made tons of the Twisted Wedge "canted valve" heads for the SBC. They were really popular back in the late 90s/early 00s, especially with the TPI crowd. That's most likely what they are. The TF casting numbers usually began with SN.
To the OP: are the valve guides shot? Then they're most likely the TF heads! Could you post a picture of the heads? Particularly the valve layout and the exhaust flange...
Marc 85Z28 is offline
Old 02-09-2012, 01:53 PM
clemente's Avatar
i checked threw the trickflow catalog and couldnt find the pn. i think that my next step will be to call them in see what is found. oh and i cant figure out how to post pictures, so any info will be appreciated.
clemente is offline
Old 02-09-2012, 01:56 PM
clemente's Avatar
oh but i did put a quick pick in my pics of the car in my garage. its under performance. like i said its a quick pic though.
clemente is offline
Old 02-09-2012, 07:18 PM
JP95ZM6's Avatar
To post an image, it first has to be uploaded someplace online so you can get a web link to it. You can use Photobucket or any other web image site, your album here, or upload as a file. Copy that link, hit the yellow square above your reply (go advanced if necessary) and paste the link in the popup. More info here: CamaroZ28.Com Message Board - FAQ: Reading and Posting Messages
JP95ZM6 is offline
Old 02-09-2012, 07:36 PM
Marc 85Z28's Avatar
That's because TrickFlow stopped making those heads a LONG time ago.
The pic in your garage? Here it is...
I see 3 things:
1. What appears to be the TrickFlow Twisted Wedge heads, the first/original design (referred to as G1).
2. Incorrect rockers.
3. Sludge!
Chances are if it's got a TPI intake, they're TF heads. Canted valve heads are usually high dollar max effort pieces with huge intake ports that won't line up with a TPI base. They're not true canted valve heads.
Old 02-09-2012, 09:24 PM
clemente's Avatar
Yeah I was very disappointed when I saw all of the sludge build up. I'll check with trick flow to see what the recommended parts were to put them on correctly and to see if it would even be worth rebuilding with these heads. Thanks for the input.
clemente is offline
Old 02-09-2012, 10:11 PM
clemente's Avatar
Oh and thanks JP for the advise on pics. I think I'll start a photo bucket account if I don't already have one
clemente is offline
Old 02-10-2012, 07:17 AM
soul strife's Avatar
Keep us updated, I'm curious as to what TF says.
soul strife is offline
Old 02-11-2012, 01:07 AM
clemente's Avatar
thanks jp. do you know how to get a full photo in the thred like the one above.
clemente is offline
Old 02-11-2012, 08:48 AM
Marc 85Z28's Avatar
Yup. Those are the TF Twisted Wedge heads, 100% sure.
You want to know how to show the picture in the thread? Read this: CamaroZ28.Com Message Board - BB Code List
Old 02-11-2012, 02:29 PM
clemente's Avatar
dont ask how i was able to find out what both of those pages where about but thank you very much!!!!!!!
clemente is offline
Quick Reply: tpi mystery canted valve heads?
