Tpi And Lobe Seperation
Old Jan 12, 2007 | 01:06 AM
  #16
quickchicken's Avatar
Originally Posted by Kevin91Z
If you have 10.41:1 compression ratio, then I dont think your heads are stock. Max lift on stock heads is about .470". If you're running .480", then you're lucky.
heads are stock 081 castings with mild port work, studs & plates.
im thinking about backing the comp down a bit by going with a .40 gasket instead of the .20 that i have now. this will make it a lil better on tuning. its pretty good now but can use a few more tweeks.
Old Jan 12, 2007 | 03:47 AM
  #17
Zepher's Avatar
I can't remember the specs of my old cam in my 305, but it was the Crane Cams Powermax 2050. It was either a 110 or 112LSA.
I was running a Stock Prom with VATS turned off.
Here is a vid of it at idle and driving down the street.
http://www.transamws6.com/video/ZepherWS6.mpg
Old Jan 12, 2007 | 07:38 AM
  #18
toby's Avatar
i have a 93 lt1 in my car with a large cam with a 108lsa it drives just fine for me. i had a tune done by ion at madz28.com. it is speed density, no maf so don't think you can't run a tight lsa just because you have fuel injection.
Old Jan 12, 2007 | 10:36 AM
  #19
Kevin91Z's Avatar
3rd Gen Tech Moderator
Originally Posted by Marc 85Z28
VERY bold (and ignorant) statement coming from someone with TPI, which happens to be one of the more expensive fuel injection systems to modify, that also returns very little...
Yeah, small cams are the way to go for performance, and carbs are for idiots. Oh wait, you're from CA
See my adjustment right above your post. I think I've done quite well with my TPI system. Others in our SoCal club have gone low 12's. But I cant drive so I'm stuck in the high 12's. Either way, my car passes CA smog easily (so do the other 12 second cars in our club); something you cant say about your cars.
CA doesnt suck, its just the liberal pussies in Los Angeles and San Francisco that ruin it for the rest of us.
Old Jan 12, 2007 | 01:47 PM
  #20
ws6transam's Avatar
I almost had a comeback for this but I realized it was blatantly off-topic and quite possibly a thread hijack.
--Dan
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
STEPHEN JOHNSON
Sep 7, 2015 02:28 PM
