tpi/ to blower carb?
Old Jun 6, 2003 | 09:48 PM
crazyk1le's Avatar
Talking tpi/ to blower carb?
i want to switch from the tpi settup i have and go with a blower carb instead, does an 1982 z28 have a smog pump, and do you act. need , in 1982 did they have a carb'd motor. i'm trying to see what i can stick in my car and pass emmisions
Old Jun 7, 2003 | 09:02 PM
fbird95's Avatar
they had two carbed 305s in 1982 if i recall correctly, both were not very imprssive on the HP note though. I'm exactly sure about the smog pump.
Old Jun 7, 2003 | 11:35 PM
crazyk1le's Avatar
Talking what i'm saying
what i'm sayin is if they had somthing that was carb'd i can pass using a carb'd engine
Old Jun 8, 2003 | 12:30 PM
Damon's Avatar
Contact Holley. They have versions of their Weiand/Holley 144 roots-style blower that are emissions legal. You will need at least a 4" cowl hood to fit it under. It will work with the stock compter-controlled QJet carb and distributor and ECM of that year.
Old Jun 8, 2003 | 04:20 PM
crazyk1le's Avatar
Unhappy 144 blower
will i need to run the q-jet carb and esm or can i use a normal carb no comp.
Old Jun 8, 2003 | 05:40 PM
TheGreatJ's Avatar
You can run a non-computer carb and non-computer distributor, but it's gonna have to be tuned carefully to pass emissions.
Old Jun 8, 2003 | 06:51 PM
87camracer's Avatar
Re: what i'm saying
no, that means if you want to run a blower carb setup and be emissions legal, you have to go with say an 82 carbed car to be legal. just because on year had a carb doesnt mean you car will.
also why not just run a centrifugal setup on your tpi? it will be a LOT easier to install, might be a bit cheaper, make the same or better hp and might get a tick or 2 better mpg.
Old Jun 8, 2003 | 09:07 PM
crazyk1le's Avatar
Talking cent. blower and tpi
i have an 87' but i can get an 82' the truth is i took the tpi apart and now i'm lost on how i'm gonna get it back togother also it's very expensive to do some real **** to these cars.
runners $400
intake$400
inj. $400
throttle body $400
wiring harness$400
cent. blower $3000
that alone equals $5000
roots blower$2,300
carb$600
total$2,900
really i'm just intimidated of the tpi ( putting it back together)
say i bought a wiring harness from howell eng. they sell a hotrod kit cleans up the wires anyways if i do with eveything will i be easier to put back together is there a book i can get to help me
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
bunker
Jan 30, 2016 08:09 PM
Kawi
Sep 28, 2015 09:01 AM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
