Top speed with 2.23's?
Old May 11, 2004 | 09:35 AM
kbog54's Avatar
Hi, I was wondering what the top speed of my car would be.
I have the 305 with CFI, and the guy before me put 2.23's in the rear instead of the stock 2.73's.
295/60r15's out back, 4 speed auto w/ overdrive and shift kit.
Any guestimates? My speedometer is a little slow because of the bigger tires, but i've had the needle almost at the bottom of the speedometer @ 3500 rpms
Old May 11, 2004 | 11:47 AM
87DJP2001's Avatar
I question The 2:23 gear ratio in 10-bolt rear??? Do you mean 3:23???
Old May 11, 2004 | 05:11 PM
buzz12586's Avatar
Or did you mean 2.73's..
Old May 11, 2004 | 06:25 PM
TheGreatJ's Avatar
Never heard of a 2.23 ratio. And if it did have them, the car would be slower off-the-line than a 3-cylinder Geo with a dead cylinder.
Old May 11, 2004 | 08:52 PM
Dave89IROC's Avatar
I used to have a lincoln with a 2.5:1 rear gear, it had a 9in.
that wasn't too bad off the line
it did have a 460/C6 combo in it though
Old May 13, 2004 | 01:43 PM
kbog54's Avatar
The guy i bought the car from told me that he swapped out the original gears ( i would assume 2.73's) and put in 2.23's. I havent taken the rear apart yet, so what would tell me the ratio thats back there?
Old May 13, 2004 | 10:21 PM
trackbird's Avatar
Sure he didn't say 3.23's?
Old May 14, 2004 | 12:18 AM
WhiteKid's Avatar
Your going to have to take off the differential cover and count the teeth on both gears and then divide the two. Obviously the higher number on top.
REDNECKISBOSS
Apr 17, 2015 07:14 AM
canbaufo
Feb 24, 2015 10:27 AM
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
NewsBot
Jan 11, 2015 06:10 PM
mark0006
Dec 25, 2014 09:50 PM
