Tires
Old Jan 8, 2003 | 06:21 PM
1984camaroz28's Avatar
Tires
Whats a Realy good set of race tires thatw ill fit on my stock 16rims i want a good hard launch.... Money is no object
Old Jan 8, 2003 | 09:43 PM
I EAT T/A's Avatar
Go check out www.tirerack.com and read all of the customer feedback.
Old Jan 8, 2003 | 09:55 PM
I mean i want like a set of M/T , phoneix , hoosier....I dont no how to messure for them for my rims
Old Jan 8, 2003 | 10:24 PM
BOTTLEDZ28's Avatar
Go outside and measure the height of your tires now. They should be around 25" to 26" tall. Take that and then find a tire that is the same height and width for the wheels you have. I hear good things about the Nitto drags.
Old Jan 8, 2003 | 11:20 PM
TheGreatJ's Avatar
Nitto 555R in 245/50-16 is a good launch tire from what I've seen...if you want M/T's then 27x10 for 16" wheels is probably the size to go with. They'll be slightly larger than your street tires.
Old Jan 8, 2003 | 11:53 PM
90rocz's Avatar
Race only: M/T ET Drags/Streets
Hot Street : BFG Drag Radials
Either way, "at the strip" only run between "12 and 16psi" for maximum grip, or so that's what I've found works best for me, and my friends agree for them too.
Don't run that low on the street ofcourse a blow out is no fun.
And don't try to use them down to the chords, a buddy of mine tried and had a blow-out at the traps at over a buck-twenty and nearly lost it, not to mention nearly soiling himself!....
The BFG's will require more heating up than the M/T's, w/o water if possible. I've found a healthy burn is the key to getting them to stick! And they do stick like glue, if they're ready. Mine stuck so hard once I broke a seat brkt and had to hold the door handle with one hand to counter the g-force to the half track mark.
The best all around street tire I've used on our cars is GoodYear's GSC, it's about a half an inch wider than most and looks even wider than that, sticks better in the rain, and is decent at the track with a good burn, and more stable at speed.(245/50/16)
And SLP sells NEW take-offs for $399/set!!!
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
rideordie
Sep 7, 2015 08:22 AM
Slayer
Jul 4, 2015 03:06 PM
