timing cover for 383
Old Feb 18, 2003 | 01:39 AM
stevem's Avatar
i ran into a little problem.
i have an 8 inch balancer now and the original or even aftermarket timing cover for a 350 will not fit.
Q-- will a 400 t cover bolt on to my 350.or what have you guys done
ps i am keeping the 8 inch balancer for now.
Old Feb 18, 2003 | 12:17 PM
Duke's Avatar
In what way won't it fit? I used a 8" balancer on my 377 and used an aftermarket cover, problem is I don't remember what brand it was. It's aluminum and doesn't have a pointer installed on it, the pointer actually bolts on to the timing cover bolts. I mean it uses them. You know.
Anyway, where is it hitting at?
Joe
Old Feb 18, 2003 | 12:31 PM
TunedPort 335's Avatar
I'm running an 8" balancer and I bought an AC Delco timing chain cover, and an adjustable timing tab.
That should do the trick
Old Feb 18, 2003 | 06:56 PM
TheGreatJ's Avatar
The generic chrome Mr Gasket timing cover has a non-welded timing pointer and will fit with the 8" balancer just fine. You can find them at any hot-rod shop or from www.summitracing.com or www.jegs.com
Old Feb 19, 2003 | 09:09 AM
Jim85IROC's Avatar
My timing cover didn't come with a timing tab, so I had no fitment problems of any kind. I bought a billet aluminum cover from Summit.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
