HSR camshaft recommendations ??
Old Feb 9, 2004 | 01:43 PM
stealthramman's Avatar
HRS Camshaft Recommendation?
Which cam?? Recommendations?
Hope you guys that have done the HSR swap can help me out.
87 IROC Z. 355 HSR, 1.6 full roller rockers, AFR 190 heads, headers/exhaust, 700R4 with 2800 stall. 3.45 rear gears. custom programmed chip.
I'm currently running a comp. cams roller 210int./220exh. with .480" lift (.512 with 1.6 rockers) and a 112* lobe seperation. (It's a 260HR-12 i think.)
I want to increase the usable RPM, make good street torque, but take advantage of the good heads for some big HP and RPM.
I want to maintain decent highway mileage and have a strong midrange. My cruise RPM is about 2500 (+-).
Old Feb 9, 2004 | 05:40 PM
kmook's Avatar
Advanced Tech Moderator
General cam recomendations should be posted in a gen spacific forum. Transfering to 3rd Gen.
Thanks.
Old Feb 9, 2004 | 08:56 PM
bmillington's Avatar
I just put a HSR and other stuff on and was wondering the same thing.
Old Feb 9, 2004 | 09:25 PM
IROCZZ3's Avatar
I have an identical setup as yours except I'm running a Comp Cams XE 230/236. .544"/.555" 112 LSA and Yank ST3500 stall converter.
Old Feb 9, 2004 | 10:38 PM
aklim's Avatar
I am getting mine from here which will be installed first and later the HSR
Old Feb 9, 2004 | 11:11 PM
Osmosis's Avatar
aklim, that link is expensive! The LT4 hot cam was priced @ 349, it's 175 here http://www.sdpc2000.com . As far as a cam that will go well with the HSR. The HSR is similar to teh mini ram/lt1 intake. I bet the lt4 hot cam would work awsome with that set up. I'm considering that cam in the near future. I think my no. 5 header tube may be casued by a re-ground cam and the duration my be wrong on no. 5. So I may be purchasing the hot cam to replace my zz3 cam. Later, HSR
Old Feb 10, 2004 | 01:40 AM
aklim's Avatar
LT-1/LT-4 HTM custom camshaft--Hyd. roller '92-'96 $349.95
That is a custom grind one. HTM is the name of the company High Tech Motorsport.
Old Feb 10, 2004 | 08:46 AM
formularpm's Avatar
Id recommend either the XR276HR or the XR282HR. The cam you have now seems very small for your setup.
Old Feb 10, 2004 | 09:26 AM
Osmosis's Avatar
What is the difference between teh custom ground hot cam and the GM hot cam?
Old Feb 11, 2004 | 09:08 PM
thanks for your input everyone.
IROCZZ3 nice car, and very nice 1/4 times! I hope mine comes close to that with the new cam.
Have you ever been on a dyno? I wonder what RWHP it's making. You like the way that cam works, ie. torque curve etc? How's it in everyday driving? Do any highway trips or anything?
Old Feb 11, 2004 | 09:11 PM
Aklim i'd love to see how your car does with the new setup!
Old Feb 11, 2004 | 09:30 PM
aklim's Avatar
One is by GM to a set of specs where emissions comes first and power second and it has to work reasonably well with their current chips. The other is set to make power first and emissions second and will require reprogramming for sure. Just my $0.02
Old Feb 11, 2004 | 10:24 PM
AutoRoc's Avatar
I'd like to see how it does with the current setup honestly.
Old Feb 11, 2004 | 11:49 PM
IROCZZ3's Avatar
Thanks- I haven't been to the dyno yet, but my guess is probably around 340 RWHP...still needs more tuning. It's a fairly big cam for a 350 but I do drive it almost everyday so street manners are pretty good. It's a little sluggish down low as expected, but having a high stall converter helps so it's not too noticeable.
Highway driving? I drive it to the track all the time which is 2 1/2 hours north, or 1 1/2 hours south depending on which track I go to.
Old Feb 12, 2004 | 04:20 PM
Formularpm: Would you say to go with 110* or 112* lobe separation on these cams? Or do you think this makes much difference overall?? I guess the 112* cam will idle a bit better.
