Is it time for new brakes??
Old Jul 7, 2004 | 03:39 PM
buzz12586's Avatar
There is a squealing noise sometimes when I drive around and it sounds like it is coming from the brakes. Once I apply the brakes it goes away. This means I need new brakes right??
Old Jul 7, 2004 | 04:19 PM
krazzycowgirl's Avatar
Check them before you replace them. The noise should get worse when you apply the brakes over time.
Old Jul 7, 2004 | 04:42 PM
PyRo9862's Avatar
Check the drums and shoes.
Mine had some really cheap pads on it when I bought it and it never did squeel. I just felt it grinding all of a sudden and when I got him I had huge scores in the rotor
Old Jul 7, 2004 | 06:11 PM
92RS305#2's Avatar
same thing was happening to my car, there is this sqeaking device located on the front left brakes that starts sqeaking horribly when your brake pads get too thin. i checked my pads and they were still pretty good so i just bent out the sqeaker a little and the noise went away. jack up your front left end and take off the tire. the sqeaker is located on the bottom part of the caliper. a flathead screwdriver used with caution should bend it out enough to stop the noise but understand you need to replace the pads soon.
Old Jul 8, 2004 | 12:45 PM
buzz12586's Avatar
Alright thanx guys, I'll check them out soon.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jb4xx
Feb 2, 2015 10:00 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
