those with true duals...
Old Apr 16, 2003 | 10:08 PM
96PoloGreenSS's Avatar
I want to put true duals on my 88 iroc, question is what kind of pipe did you use, x pipe or what kind, and what kind of mufflers you used. and how much better will it sound then just having one flowmaster on the back.
Old Apr 17, 2003 | 07:23 AM
teke184's Avatar
why are you planning on putting duals on a stock tpi car? even if it's a 350 you don't need that much exhaust flow?
Xpipes sound better and are said to flow a bit better than H pipes. Heddman sells one in jegs or summit or you could look into a Bassani Xpipe.
a good muffler to use is just some dynomax bullets (or similar) since they are compact and will tuck up under the car nicely.
Old Apr 17, 2003 | 07:27 AM
irocz8957's Avatar
the x pipes will be good for tru duals it's sounds alot better then h pipes also!
Old Apr 17, 2003 | 08:33 AM
What x pipe is it in hedman they have 2 kinds x pipe kit extreme and there's the x pipe equalizer. Which one exactly should i get. And is that and the mufflers all i need?
Old Apr 18, 2003 | 11:24 AM
ebmiller88's Avatar
Willie on over on TGO has THE nicest true dual setup I've seen. More info and pics here:
http://www.thirdgen.org/techbb2/show...highlight=dual
and
Also,
HTH...Ed
RUENUF
Mar 13, 2016 03:37 PM
generaldave
Sep 25, 2015 06:48 PM
Slayer
Aug 17, 2015 03:55 PM
meissen
Aug 11, 2015 06:05 AM
