there has to be a good shifter
Old May 31, 2007 | 03:13 PM
MyNameIsMud's Avatar
that is like this description.... Buy Hurst 2920000 - Chevy Camaro Shifter 1983 - 1989 HURST DUAL GATE 2 AUTOMATIC SHIFTER -- You Select From 2 Separate Shift Gates, Street For Normal Street Driving Automatic Shifting Or Race For Performance Driving, That Gives You Fixed Gate Shift Control 1 - 2 And 2 - 3 Shifting Selection Without Overshifting Into Neutral, Cable Operated, Kit Comes With Chrome Shifter, Black Shifter ****, Black Console With Black Hurst Logo Trim Plate, Illuminated Shifter Selector, Hardware And Easy To Follow Installation Instructions. I have a 91 z28 camaro its an automatic and im looking for something just like this can some one pleae help me!! please thanks in advance
Old May 31, 2007 | 03:24 PM
jayman350's Avatar
check out this
B&M Mega Shifter
I had the megashifter for about 3 years and I loved it.... once it was adjusted correctly and after i had shaved off the tab on the front that pokes out when you downshift. You can bang as hard as you want and it will only go up or down 1 gear at a time. You only have to pull up on the t-handle to shift from park, as opposed to having to pull the lever on each shift.
there are more than a few options out there
Old May 31, 2007 | 03:26 PM
awesome i really appreciate it if anyone knows any others id love to have as many options as possible.
Old May 31, 2007 | 03:46 PM
would this one work ? http://www.bowtieoverdrives.com/cata...php?ITEMID=160
what about this ? http://www.bowtieoverdrives.com/cata...php?ITEMID=165
just to let everyone know i have a 91 z29 camaro stock tranny
Old May 31, 2007 | 05:22 PM
jayman350's Avatar
my bad, the Pro Stick won't fit under the console, same thing with those you listed there
B&M QuickSilver
I used this search to find what will fit
Old Jun 1, 2007 | 11:50 AM
Z28SORR's Avatar
http://web.camaross.com/forums/showthread.php?t=522817
Old Jun 1, 2007 | 03:16 PM
Duke's Avatar
Well, any shifter will work i fyou can handle a little fabrication. We put a Pro Stick in my buddy's IROC, it just required a 1.5" thick spacer
Old Jun 1, 2007 | 05:33 PM
now if i get the quicksilver... now when i want to use it almost like a stick i go in 1st then 2nd then drive? what am i not seeing im new to this part of cars im an engine guy. I was wanting a shifter that i can use almost like a stick in the way of i can rev to 5000 or whatever then shift... now would i have to let go of the gas when i shift it or would i be able to shift right through? thanks in advance
Old Jun 1, 2007 | 05:39 PM
i just feel like im missing something here like how am i banging through gears? i only see 1 2 d n r p where are my gears??
Old Jun 2, 2007 | 03:43 PM
somebody anybody? how were are you banging through gears on a shifter like this im totally lost
Old Jun 2, 2007 | 03:58 PM
chevynutman's Avatar
b&m also has a ratchet shifter that is for 82-92 f-bodies w/4 speed it doesn't stop before going into neutral but it will only go one gear at a time so as long as you remember to count shifts you will be fine
karpetcm
Feb 9, 2015 09:21 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
