Is there a good A/C bracket out there for 3RD-Gen LT1 Swap?
Old Aug 18, 2005 | 11:33 PM
Jacobs454's Avatar
'Saay fellow F-body FREAKS!! I'm looking for a good A/C bracket for an LT1 swap in a 3RD gen. I need one that'll support ALL accessories INCLUDING the smog pump. I saw one but it was for "off-road" use. THat sucks because every inspection station in three counties here in NC checks for smog-controls, all of 'em (no, I MEAN that - there's no escaping the long arm of the law here in Mayberry). If you're smoking a cigar when you pull into the garage they'll fail it. Y'all know about the misfitting A/C compressor incompatibility of dropping a LT1 in a 3RD gen Camaro. Aside from grinding at the frame (not me) I either delete the A/C (again, not me) or mount it elsewhere. PLEASE help me out here. Thanks!
Old Aug 18, 2005 | 11:45 PM
IROCZZ3's Avatar
Re: Is there a good A/C bracket out there for 3RD-Gen LT1 Swap?
I'm pretty sure you can use a Vette setup if you do not want to notch your crossmember.
Old Aug 19, 2005 | 12:48 AM
Zepher's Avatar
Yes, the Vette setup is the best one to use, but is costly if you buy new. Street and Performance sells the entire setup for about $900.
We used that setup on my friends LT1 swap into his 82 Trans Am,
you can browse the pics here,
http://www.transamws6.com/pics/82_ta/
Old Aug 19, 2005 | 05:03 PM
Runin2Nite's Avatar
y dont you register the car as a show car...then no emmisions!!!
HectorM52
Jul 30, 2017 11:46 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
cmdeshon
Jan 4, 2015 11:15 AM
CaRParts102
Dec 6, 2014 08:45 AM
Ricardo
Nov 29, 2014 10:58 AM
