temp problems
Old Aug 22, 2005 | 02:38 PM
1fas92's Avatar
temp problems
Hello
I have a 1992 Z28 with the fast computer (ecm). It seems that the car runs a little on the warm side.
The main question is, The laptop says through the ccom dashboard view my temperature is below 200 F or right around. But the gauge in my dash (stock Gauge) says it is running 230-250 way to hot for just driving on the highway & of course in town or just driving at all.
I like the temps the laptop gives me. What do you think the problem is? And any recommendations?
Thanks,
Robbie
1fas92
Old Aug 22, 2005 | 03:09 PM
Rice Killer87's Avatar
Re: temp problems
Could try replacing the temp. sending unit. I believe its in the driver side head between cylinders 1 & 3.
EDIT: Are the fans working good? Are they coming on and off at the right time? Maybe you could adjust them to come on sooner to keep it cooler.
Im not sure what you can/cant do w/ a FAST ecm.
Old Aug 22, 2005 | 03:34 PM
1fas92's Avatar
Re: temp problems
The fans are working good. They are connected to the ecm & they both come on at 100 f. With the fast ecm you can change it to whatever temp you want. I think your right about the sending unit. I will change it today.
But still the laptop temp says the car is not running to hot. I guess it could be the wrong temp sender on the car for it to not be working correctly with the dash gauge. Here in Dallas the outside temps are pretty close to 100 with the heat index over 100.
Thanks,
Robbie
1fas92
Old Aug 22, 2005 | 03:52 PM
91-Z28-L98's Avatar
Re: temp problems
The ECM reads the temperature from right by the thermostat in the block or intake manifold, I forget which. The temp gauge reads from the head between cylinders 1 and 3. It makes sense that the temp at the head would be higher than by the thermostat.
Old Aug 22, 2005 | 04:05 PM
1fas92's Avatar
Re: temp problems
Right now the one in question is the coolant temp, not the air temp. I am pretty sure these cars only have one coolant temp sending unit, right.
Robbie
1fas92
Old Aug 22, 2005 | 04:20 PM
Dave89IROC's Avatar
Re: temp problems
Robbie
1fas92
Nope, 2
one in the intake near the t-stat is the ECT sensor, for the computer, and one in the cylinder head between cylinders 1&3 that feeds the gauge
Old Aug 22, 2005 | 04:46 PM
1fas92's Avatar
Re: temp problems
What do you think about the overall heating problem? Could I have put the wrong coolant temp sending unit on the cylinder head or do you think the car is really running that hot.
Thanks,
Robbie
1fas92
Originally Posted by Dave89IROC
Nope, 2
Old Aug 22, 2005 | 04:56 PM
Dave89IROC's Avatar
Re: temp problems
Thanks,
Robbie
1fas92
if it is just the stock gauge, they are notoriously inaccurate
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
warmeck
Apr 27, 2015 04:34 PM
HCz28
Jan 11, 2015 11:21 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
