Temp. gauge goes to 240!! but doesn't overheat??
Originally posted by Slow91z
You people aren't reading obviously... SHE HAS A CARBERATED 84 WITH A MECHANICAL GUAGE...It's not the second fan there, isn't one...no computer to deal with either (not one that does anything with cooling anyway)...
Hehe thanks guys, ya I was reading some of the posts and I was thinking there is no second fan, or I'm blind. I did take the thermastat out and it did help it a little. Sometime this week I'm going to change the oil and flush the radiator out. And the car is running perfect, not to rich not to lean. Thanks for the help
thanks,
Katy B
thanks,
Katy B
Katy B
Katy B
T.
Originally posted by doug791
doubt its your coolant sensor for 2 reasons....one it usually trips a code either hi or low....and also it has an effect on your air/fuel ratio so your car will either run rich or lean if its going bad.
Try reading the original post.
The Flex fan was on it when I bought it. The fan shroud is still on it too.
I will have to try and maybe order a better thermostat.
ElCamino: can you explain to me what water wetter is?? I have never heard of that before, believe it or not! lol
Thanks,
Katy
Thanks,
Katy
Guess you didn't read mine...or his response
For real.
For real.
[i]Whoa, thanks for your two cents or should I say two words. This doesn't even pertain to the thread. [/B]
Oh and if you really have a problem with off topic posts why did you post one.
