Tech question of the day
Old Apr 17, 2003 | 10:31 AM
pigsticker's Avatar
I've got a 1992 z28 with a 350 TPI. I'm riding down the street the other day when the car died. I put it in neutral and did manage to get it cranked back up. I wasn't far from the house so I drove it home. Now the car won't crank, all it'll do is just turn over. Every now and then it'll make a good effort to crank but won't. I've replaced the plugs, dist. cap, rotor, remote coil, replaced o-rings in the fuel rail, installed adjustable fuel reg. o-rings on injectors. Some of this stuff doesn't have anything to do with my problem, it just needed to be done. I've got about 50 pounds of pressure at the fuel rail. I've also replaced the plugs wires. So whats the deal? Oh yeah, I had my ignition module checked- it was good.
Old Apr 17, 2003 | 10:43 AM
RobsWS6's Avatar
Check for blown fuses.
Old Apr 17, 2003 | 10:51 AM
pigsticker's Avatar
I forgot to mention that I did check for blown fuses and didn't find any bad ones.
Old Apr 17, 2003 | 11:57 AM
irocz8957's Avatar
it could be your fuel pump, or you said you had a fuel pressure regulator make sure thats set right!
Old Apr 17, 2003 | 11:59 AM
irocz8957's Avatar
oh yeah i forgot to ask what type of fuel pressure regulator do you have!
Old Apr 17, 2003 | 06:30 PM
TheGreatJ's Avatar
Pickup coil. In the bottom of the distributor where the module is there's a little silver can with a black wire coming out of it. They are notorious for burning up and being hard to diagnose. It may not be the problem but it's the only ignition part you haven't checked.
Old Apr 17, 2003 | 08:37 PM
Zepher's Avatar
Could be a bad memcal or ECM.
Old Apr 17, 2003 | 08:39 PM
Zepher's Avatar
If the pump was bad and he had pressure, the car would fire up and start to stumble. It sounds like the car just turns over and over.
Old Apr 17, 2003 | 08:46 PM
Zepher's Avatar
Here are some things to check.
Use a test light on one of the injectors and see if the light pulses, if it does then the injectors are getting a pulse.
If it doesn't pulse, it could be injector fuses, but you checked those already, or the distributor module underneath the rotor, or the Memcal in the ECM or the ECM itself.
Also check to see if you are getting power to the ECM, there is 2 power sources for the ECM, one comes right from the battery which is an orange wire and one from the ignition which I think is red, can't remember, if one of those isn't working, the car won't fire up.
You can also spray some starter fluid into the plenum and see if it fires up.
Sometimes if the disrtibutor module goes bad and you spray starter fluid into the engine the car will fire up and the ECM will start doing the Injector pulses. ECM doesn't start firing the injectors until 300rpm, module does the firing before that.
Old Apr 18, 2003 | 12:14 PM
aklim's Avatar
Stick a spark plug onto the wire and ground the thread end and crank. See if there is spark. If so, check fuel pressure with the schraeder valve on the rail. After that, check injector pulses like mentioned.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Caps94ZODG
10
Sep 9, 2002 12:08 AM
