TCI breakway 2400 converter wont slide in
I have a brand new 242960 non lock up stall converter and it wont slide into the 700r4, The trans is a 27 spline and so is the converter. Is there something im doing wrong, or is it defective.
Re: TCI breakway 2400 converter wont slide in
Are you sure that the convertor is a 27 spline? Do your best to count the amount of splines. Just wiggle it around and push it in, should click twice..
Craig
Craig
Yup i counted both the converter and the tranny. When i put the converter on it goes in alittle bit and then it stops. Even if i push, wiggle ,and turn it nothing has worked.
You have to keep spinning it to get past all of the shafts, I think. Mine first went in like a half n inch then I spun it and it went in a little bit more then I turned it again and it clicked in and then it was all the way on. I put a B&M torquemaster on my 700.
you may need to play with it for a while, the clearances may be pretty tight, we had to wiggle, spin, push, pull for about 20 minute to get my buddies 4500 stall vigilante onto his input shaft
I have tried spinning it and everything for like a half hour and it wouldnt move the rest of the way in. Do you think it would be ok to use a rubber hammer to push it in the rest of the way.
Yes that was a no for the rubber hammer. Do not pound your convertor in. You should take it off, fill it over 1/2 full with tranny fluid and tru again. Spin it both ways to ensure that you are doing it correctly. I have installed 2 of them on my 700 and they both seemed to pull themselved on while I was spinning them.
Well i called TCI this morning and they said sense i have the non lock up converter that i have to cut the end of the input shaft off and it will go right on.
Aug 5, 2015 08:35 AM
detroitmuscle
Jul 31, 2015 04:21 AM
