TBI to Carb Question
Old Jun 30, 2005 | 10:56 AM
usa1racing's Avatar
I'm swapping from TBI to carb in an 88 Camaro. Can I use a dead-head regulator or do I have to use a bypass style. I know the article on thirdgen.org says to use a bypass style regulator, but I assumed that was for the high pressure TPI system. Thoughts?
Old Jun 30, 2005 | 11:51 AM
Z28SORR's Avatar
Re: TBI to Carb Question
Your carb can not take more then about 6 to 7psi of fuel pressure. Any more than this and the floates will not be able to cut off the fuel flow into the carb.
Get a fuel pressure gage and check it.
Old Jun 30, 2005 | 12:10 PM
usa1racing's Avatar
I will run anywhere between 6 and 7.5 psi of fuel pressure, but I need to know whether or not I have to use a bypass style regulator.
Old Jun 30, 2005 | 12:59 PM
Z28SORR's Avatar
A bypass regulator is always a good idea when using a high volume/pressure pump. If you dead head this pump you will probably burn up the pump, blow a fuel line, or blow the regualtor.
Old Jun 30, 2005 | 07:06 PM
blown3rdgen's Avatar
Need a return style reg. I'm selling my mallory #4309 if interested pm me
Matt
Old Jul 1, 2005 | 02:28 PM
AutoRoc's Avatar
Buy this guys Mallory 4309 regulator or get a new one. Aeromotive makes a Universal Bypass style regulator also. I've used the Mallory with great success.
Your TBI needs to be regulated DOWN to 5-7psi. I believe it's 10 or 14PSI stock and that will definately make the carb spit fuel everywhere/in and out of the engine.
Goodluck!
Old Jul 1, 2005 | 03:14 PM
usa1racing's Avatar
PM sent to blown3rdgen on the Mallory Regulator.
bose
Jan 30, 2015 02:36 PM
Amshnock
14
Jan 18, 2015 11:47 AM
InfernalVortex
Jan 17, 2015 09:35 AM
markaubuchon
Jan 14, 2015 01:48 AM
