TB vacuum port ??'s
Old Apr 3, 2003 | 12:13 PM
undertaker's Avatar
TB vacuum port ??'s
can someone explain to me what each of these two vacuum ports behind the tps are for? I was thinking of using the larger diameter one for the vacuum line for my truck's master cylinder/powerbrakes any thoughts guys? is it a vacuum fitting? I'm not running any sort of emission stuff so thats not a consideration
Old Apr 3, 2003 | 04:52 PM
Lungz's Avatar
one goes to the valve cover and the other goes to the vacuum canister, I think the top one goes to the valve cover breather and the bottom one goes to the vacuum canister.
EDIT:
http://www.mrgasket.com/accelpdf/ChevyLT1.pdf
this sit ehas some info, I can only find indication for one of the barbs, I know one of my side ones goes to the vacuum but I have some minute problems with that line that I am working out, hopefully somebody else knows so I can properly route it, pictures would be cool too
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
